Results 1 to 5 of 5
Thread: What kind of valve do I have to buy for under the kitchen sink?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default What kind of valve do I have to buy for under the kitchen sink?
    I think it's the hot water side. I guess I have to turn off the water, cut the pipe underneath the connector, put on the valve, then turn the water back on. Any steps to take before or after turning off the houses water?
    What kind of valve should I buy, exactly? I wanna get a sharkbite version because soldering underneath there would be tough (and I dont have a lot of experience soldering). Here are some pics; i have no idea what the little black wire/thing is, but the hose that attaches to the faucet is off (you can see the hole in the top). Its old as heck.
    Thanks a ton!
    You have a double shutoff there. The tubing to the right is for the dishwasher. You may want to pick up a compression double stop with two handles. That way you don't shut off both the dishwasher and the kitchen sink while when is being repaired.
    I don't know why you would sharkbite something so simple. You just slide on a new shutoff and snug it up with a cresent wrench.
    Are we forgetting how to use tools?
    Mar 2013
    Here
    I appreciate the info! Btw, thanks for the forums, I have learned a lot here!
    Yakima WA
    Instead of a Sharkbite, you should use a compression fitting. You place the nut on the pipe, follow with the compression ring then slip the valve over the pipe end. Screw the nut onto the valve which pushes the ring into place. Tighten the nut with a wrench. Done. These are preferred to sweat fittings because they don't require heat in a tough position and their simplicity makes them very easy to install, or remove and replace if necessary.
    Mar 2013
    Here
    Guys, I did it! Thanks a lot for the help! Took your advice and used the compression fitting. Went smoothly. I should probably replace the other valve too. I'm going to replace all the stuff down there. Anyway, thanks again for the advice!
  1. Upstairs Kitchen sink draining into basement kitchen sink
    By DIYRENO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2012, 05:14 AM
  2. what kind of valve
    By mak123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-27-2009, 02:33 PM
  3. Kitchen sink single handle valve operation..
    By pmaru77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-07-2009, 04:54 PM
  4. Water shut off valve leaks under kitchen sink
    By ryan_siefring23 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2008, 06:48 PM
  5. What kind of backwater valve to use ?
    By Pan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-22-2008, 07:21 PM
