Results 1 to 5 of 5
Thread: short radius 90 degree elbow under toilet
    DIY Junior Member poky1234's Avatar
    Dec 2012
    Woodbridge Ontario
    Default short radius 90 degree elbow under toilet
    Hello,
    I would like to know, if by Canadian code, a 3 inch short radius 90 degree elbow can be used under a toilet. If I use a long sweep 90 or 2 45's it sticks out above the floor too far.
    Thanks.
    Jan 2008
    I prefer to use a 4x3 closet bend, which takes less space and accepts a full size flange.
    Dec 2012
    Woodbridge Ontario
    Thanks for the answer, I'll look for one of those.
    You would want a "spigot" closet bend, not a hub one.
    Dec 2012
    Woodbridge Ontario
    Thanks for your time to answer these questions , you guys are great! I'll go find a spigot closet bend.
  1. Elbow, Closet Elbow, or Long Turn Elbow for closet flange connection
    By Drewski123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2011, 04:52 PM
  2. Relocating Toilet - 45 degree or 90 degree fitting?
    By ED1 in forum Toilet Forum discussions
    Last Post: 09-13-2009, 09:35 AM
  3. Bypass Tub/Shower Door w/radius corners?
    By Wicked in forum Shower & bathtub Forum & Blog
    Last Post: 08-30-2008, 04:18 PM
  4. I need a 1 1/4" slip joint 90 degree elbow.
    By enviroko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-25-2007, 10:08 AM
  5. 11 1/4 degree ABS elbow?
    By Blade_Jones in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-18-2006, 07:05 AM
