Results 1 to 13 of 13
Thread: How do I remove the top screen from a control valve?
Hybrid View
    Nov 2005
    Central Florida
    Default How do I remove the top screen from a control valve?
    In this case, an Autotrol 255... doesn't seem to want to untwist. I'm leaning toward crushing the screen and replacing it when I reinstall the valve, but if there's a way to do it without destroying it, I'd love to save the big bucks. Are top screens interchangeable among different valve brands?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    They do get stuck, you just have to work at it. If it is full of iron, use some iron out. I've used the same upper basket on Clack as well as Fleck valves.
    Nov 2005
    Central Florida
    This one isn't stuck -- valve has never been used (it's along story) -- and it twists back and forth freely about 1/32" along the diameter. There are 4 little locking tabs on the outer rim (if it's anythinglike the Fleck top basket) that are doing a damn fine job of locking. I see no way to unlock it
    Jan 2012
    California
    The clack stacked screens tend to lock in almost permanently. The standard screens should be removable. Clack and Fleck screens are deifinitely different. The Clack screens will usually work in Fleck, the Fleck screens have difficulty working in Clacks without trimming 2 of the tabs on the screen.
    Keep at it, I doubt you will damage the valve, just the screen, and they are cheap.
    Nov 2005
    Central Florida
    Cheap is good. This one is history .
    Nov 2010
    Ocala, Florida
    I didn't know that. I guess I've always used the Clack upper basket unknowingly, which as you stated fits on the Fleck, and thought they were interchangable. Thanks for the info.
    Nov 2005
    Central Florida
    As I stated, I'm working with an Autotrol (GE) 255 valve. Dealer who sold me the valve gave me a Fleck screen, I think. Says it'll work. I'll find out tomorrow.
  1. How do I remove the brine piston assembly at the control head of a Fleck 2510?
    By Biddle in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-01-2011, 09:22 PM
  2. Air Control Valve
    By Chrisw1958 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2010, 01:59 PM
  3. cant remove cold valve
    By hotrod351 in forum Shower & bathtub Forum & Blog
    Last Post: 01-20-2009, 06:58 AM
  4. remove RPZ valve?
    By lawnpsycho in forum Irrigation / Sprinkler Forum
    Last Post: 11-08-2008, 06:30 AM
  5. Unable to remove control handles/lever
    By maree in forum Shower & bathtub Forum & Blog
    Last Post: 06-27-2008, 05:20 PM
