Thread: I have a leak
    DIY Junior Member Brewer's Avatar
    Mar 2013
    SC
    Default I have a leak
    I recently purchased a house and my yard sprinklers and pool are supplied by well water. I noticed today that a faucet water line by the pool is leaking under ground and flooding my yard. I have a captive air tank well system (only one line going in/out), how do I turn the water off so I can repair the broken line. I switched off the Well circuit breaker tonight and opened up the faucet. I let the water run for appox 20 minutes, but the water kept flowing strong. How long should it take for the water to stop? Will the air deplete in the tank with the well turned off and water depleted from the tank? Will I have to add pressure to the tank before I switch the well pump back on?
    Sorry for so many questions, just moved in approx 3 months ago, and this is my first experience with a well. If I can get the water shut off repairing the broken water line wont be a problem. I just need to know if I should call a plumber to take care of the well. Any advice will be appreciated. Thanks!
    Aug 2009
    South*East
    There should be a valve at the pressure tank.
    John
    Moderator valveman's Avatar
    Mar 2006
    If you don't have a valve after the pressure tank to shut off the water to the line, just turn off the pump and drain the tank. If you have a big tank, like 80 gallon size, it holds about 25 gallons of water. With a small faucet, putting out 2 or 3 GPM, it might take 7 to 12 minutes to drain the tank. With the pump shut off, the water will stop when the tank is empty.
  1. Tub leak, stain in ceiling below - How to find leak???
    By Chuck1026 in forum Shower & bathtub Forum & Blog
    Last Post: 10-03-2013, 07:22 PM
  2. PRV Leak
    By foxhome01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-19-2009, 05:45 AM
  3. hot wtr leak in slab AND sewage leak possible?
    By dzgrrl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-15-2009, 02:02 PM
  4. Foot Valve leak vs. supply leak
    By bikeguy18974 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-16-2008, 05:09 PM
  5. What causes a tank to leak and then not leak
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2006, 08:01 AM
