Results 1 to 4 of 4
Thread: actual door opening width
    DIY Senior Member diyfun's Avatar
    May 2011
    MA
    Default actual door opening width
    I measured the width of my existing door panel and got 27-3/4", it is a 28" wide door or 30" wide door?
    or
    what's the actual door opening width for a 28" wide door? I need to know if the opening is wide enough for a table which is 26" wide.
    It's a 28" door. But, the actual opening is smaller because of the door stops. If you take the door off, it should just make it through. With it on, you'd have to subtract at least the thickness of the door.
    Plumber jimbo's Avatar
    It is a 28" ( trade size 2-4, meaning 2'4"). Then is was planed about 1/4" at install. So your opening between jambs is close to 28", but subtract about 3/8" each sde for stops.
    A table can be fudged through a much smaller opening, buy easing the legs "around the corner" at the side opposite the hinges
    Your table is 26" wide and the door opening is 27 3/4". What is the problem? The only problem would be if the door does not "swing" open far enough to give you the full opening, in which case, remove the hinge pins and put the door off to the side somewhere.
  1. door opening
    By jetlag in forum Remodel Forum & Blog
    Last Post: 10-14-2010, 06:31 PM
  2. Garage Door Opening Wall 2x4 or 2x6?
    By Lakee911 in forum Remodel Forum & Blog
    Last Post: 08-11-2009, 01:50 PM
  3. Garage door in RO less than door width?
    By jrfiero in forum Remodel Forum & Blog
    Last Post: 06-19-2009, 05:36 PM
  4. Swinging shower door opening too small
    By shirleybouncy in forum Shower & bathtub Forum & Blog
    Last Post: 01-24-2009, 05:09 PM
  5. Rough Opening for Door
    By nelsonba in forum Remodel Forum & Blog
    Last Post: 11-21-2007, 03:36 AM
