Results 1 to 5 of 5
Thread: Having trouble connecting 3/4" copper pipe to 3/4" fittings.
    DIY Junior Member cyelrah1's Avatar
    Mar 2013
    Livermore, CA
    Post Having trouble connecting 3/4" copper pipe to 3/4" fittings.
    Hi. I'm a beginner DIY whole house copper re piper. I have some experience with re piping and I've practiced soldering sections before beginning the job. I am aware that the pipe that is to be soldered needs to be cleaned to a bright finish, wiped off and fluxed before soldering. My problem is that I am have trouble with the simple task of connecting 10' sections of 3/4" copper to unions and 90 elbow's. The connections seems really tight and have to be worked on by turning back and forth. I'm afraid the connections are so tight that the solder won't flow properly. I bought the pipe sections at Orchard Supply and the fittings at Lowe's, but that shouldn't make a difference..........should it? Thanks
    If you can get the 90's and couplings on the pipe, your're fine.
    Mar 2013
    Livermore, CA
    Thanks Terry, Any tips on securing copper to floor joists? I have copper plated hanger. Will the pipe be noisy when water is flowing?
    DIY Senior Member DougB's Avatar
    Jun 2010
    Minneapolis - Land of 10,000 taxes
    When you have trouble with copper tubing and fittings, it's probably that the tubing was mishandled, and it's a little out of round. Before I buy tubing I make sure that a sweat coupling fit's easily - if not I try another piece of copper.
    The single ear / double ear straps are OK.
    It would be almost impossible for a copper tube and fitting to be so tight that the joint would be defective. IF they were too TIGHT, you would not even be able to get the tubing inserted. But, they can be too LOOSE to make a good joint. A sweat joint depends on a close connection between the tube and fitting.
  1. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2013, 09:34 PM
  2. Connecting 1/2" copper to old 3/4" brass pipe
    By sean farrell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2012, 12:46 PM
  3. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
    By dayster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2011, 04:51 PM
  4. What is best/safest way to cut cast iron drain pipe (or "undo" the fittings)?
    By diecastdawg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2010, 10:53 AM
  5. "ez-sweat" copper fittings vs. old school sweating
    By oldsquawky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-19-2005, 05:45 PM
