Results 1 to 2 of 2
Thread: New Well Need Treatment Advice
    DIY Junior Member rgabriel's Avatar
    Jul 2012
    Maryland
    Question New Well Need Treatment Advice
    I had a new well put in a few months ago, I'm finally getting around to finding a treatment solution.
    My well is running a CSV Sidekick Setup, and not a standard pressure tank setup.
    Water Test Results
    Hydrogen Sulfide - 2 mg/L
    Hardness - 8 mg/L (as CaCO3)
    Hardness (gpg) - .5 grains/gallon
    Iron - 1.75 mg/L
    Magnesium - .7 mg/L
    Nitrogen, nitrate - <0.1 mg/L
    Nitrogen, nitrite - <0.1 mg/L
    PH - 5.6
    Sulfate - 14 mg/L
    Tot. diss. solids, estimated - 42 mg/L
    Bacteria tests came back negative, but I think I have iron bacteria. In the toliet tanks, I have a fuzzy red slime in the corners, under the water. The tanks are completely lined in a red film. Report has a ton of other stuff on it, but most of it is for trace elements and chemicals, everything came back not detected.
    My current thoughts were to treat the PH with soda ash injection, and the mag/iron/sulfide/iron bacteria with hydrogen peroxide injection. I was thinking of using a Stenner proportional injection system(due to the fact I have a CSV and my flow rates are variable) with dual pumps(one for soda ash, one for hydrogen peroxide), 80 gallon contact tank, and a catalytic carbon back washing filter at the end. I'm not firm on the idea, it's just what I came up with from my research, looking for others opinion's.
    Thank you!
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Sounds to me you everything under control. You may want to retest the hardness after the injection pumps are installed. You could go with a pH neutralizer instead of injection.
  1. Seeking treatment advice for well water
    By Kelly Kestler in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-29-2012, 08:31 PM
  2. Water treatment advice
    By kg2k in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-23-2011, 09:12 AM
  3. Help with treatment
    By alternety in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-06-2011, 03:03 PM
  4. need advice on water treatment system
    By bronzemaxell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-16-2010, 09:52 AM
  5. Need help with water treatment!!
    By tntg in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-28-2008, 04:55 AM
