Crowphonic
We deduced that the Switch Control was no longer working. We purchased a new one and installed it. On flicking the reset lever on the pressure switch, this caused the new Switch Control to blow up.
Any ideas why this would be? Do we need a new pressure switch and guage as well as a new switch control? Do we need a switch control with more hp? The old one and replacement one were .5HP - should we increase to .75HP?
Is it more likely to be that the pump is broken/jammed and that is why, when resetting, it is causing the switch control to blow?
Thanks in advance.
Thanks in advance.
