Results 1 to 12 of 12
Thread: venting issue
    DIY Junior Member Tricky Ricky's Avatar
    Mar 2013
    ontario canada
    Default venting issue
    hello, im installing a new bathroom in the basement and im looking for options to vent it, i have 2 stacks coming into the bsement but both have washrooms and other attached to them on the second story and first, is it code to vent to the outside at ground lvl...or do i have to run a new stack up to attic or is there a way to attach to the stacks without wet venting ? i'm kinda stuck till i figure this out so i can continue with the drywall...all comments welcome...thks
    Wet venting is for a bathroom group (shower,lav, toilet) on the same floor. Not for between floors.
    A vent from the basement typically exits through the roof, or ties in at a vent 42" above the second floor.
    Mar 2013
    ontario canada
    so its against code to tie a vent into the stack at basement lvl with drains above....so i have to run a new stack to the second lvl above the other drains or a new vent to the roof. correct?
    Mar 2013
    ontario canada
    also, would a 2 inch vent be good for shower sink tiolet all the way to the roof or should i enlarge the vent to 3 ?
    Mar 2013
    ontario canada
    looking at it again...im going to run a 2 inch vent from the basement ..up three feet...over the bathroom which is about 6 ft..into the garage then up about 10 ft..then over about 3 ft and then up through the roof about 3 ft....does this meet venting codes and the horizontal allowences ?
    2" will vent a bathroom group assuming you have other vents in the system to make up for the exit sizing.
    With a three bath home, I will use two 2" vents and one 1.5" vent. That's the same as a single 3"
    Mar 2013
    ontario canada
    the basment bathroom (shower, sink, toilet ) will have its own stack...2 inch through the roof of the garage..nothing else will be piped on it, does that meet code...or once im in the garage should i expand to 3 inch? Im not touching the exsisting stacks. they are to hard to get at without ripping walls apart and the wife would have my head...lol
    In some cold areas, they will require upsizing the vent through the roof because of frost.
    We don't do that in Seattle.
    Mar 2013
    ontario canada
    makes sense....thks for the answers
    Mar 2013
    ontario canada
    got one more quick question...in this pic...what kind of tee should go here...Name:  Untitled.jpg
    Since that is above the flood level and it's for the vent, a santee works.
    You can use a san tee or a "vent tee", although a vent tee usually costs more. The vent through the garage roof has to be a minimum distance away from any second story windows.
  1. Main line clogged or venting issue
    By rhino0628 in forum Drain Cleaning
    Last Post: 11-25-2009, 08:43 PM
  2. Re-venting issue
    By Armafair in forum Plumbing Forum Discussion & Blog
    Last Post: 10-31-2008, 12:19 PM
  3. Replies: 34
    Last Post: 10-22-2008, 06:49 PM
  4. Kichen Sink Venting Issue
    By Gbuilder in forum Plumbing Forum Discussion & Blog
    Last Post: 09-04-2007, 08:25 PM
  5. New tub drain gurgles... venting issue?
    By AMP in forum Plumbing Forum Discussion & Blog
    Last Post: 06-18-2006, 06:31 PM
