Results 1 to 10 of 10
Thread: Well Mate Problems - Low Pressure
    DIY Junior Member Crowphonic's Avatar
    Mar 2013
    Nova Scotia
    Default Well Mate Problems - Low Pressure
    I hope someone can help! We have a Well Mate Pressure Tank. No problems to date and then this morning we have uber low pressure. I have tried moving the reset lever to introduce more pressure but it didn't work. Am I looking at a reset lever issue or something more substantial. I apologise in advance if my terminology is incorrect - I don't have much of a clue!
    Moderator valveman's Avatar
    Mar 2006
    Do you have a submersible pump or an above ground jet pump?
    Mar 2013
    Nova Scotia
    A submersible. I am thinking it may be the pressure switch - I tested it with a volt tester and one side showed a charge and the other did not. Is this likely to be the issue?
    Feb 2011
    NW Ontario, Canada
    Is it a 120V or 240V circuit?
    Mar 2013
    Nova Scotia
    I honestly don't know - though would guess at it being a 240v
    Feb 2011
    NW Ontario, Canada
    Then you need to trace back to the breaker panel and see if it is 240V and if so see if both legs are hot. It could be a bad breaker.
    Mar 2013
    Nova Scotia
    OK - I will have my husband check it out tonight. Thank you!
    Mar 2013
    Nova Scotia
    If it was only a 120v - would only one side be live anyway?
    Feb 2011
    NW Ontario, Canada
    On a 120V circuit, one side is hot and the other is neutral so yes, only one side would be "live".
    Mar 2013
    Nova Scotia
    Okay, so we had an electrician friend come over to test the voltage - he thought it was the switch control capacitor - so we went and got a new one. Installed it, moved the reset to prime and it blew up. Why? I am assuming the last one blew up as well - why are they blowing up?
  1. Water Mate WM-6 question.
    By Ryan Seamone in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-06-2010, 10:40 AM
  2. 2nd Gerber Viper with problems? Tank to bowl wont mate level......
    By Dr_Jim in forum Toilet Forum discussions
    Last Post: 01-18-2010, 03:39 PM
  3. Flush-Mate toilet at new Motel 6
    By mjnelson99 in forum Toilet Forum discussions
    Last Post: 06-25-2007, 05:55 AM
  4. Flush Mate
    By jleeo in forum Toilet Forum discussions
    Last Post: 04-26-2005, 12:52 PM
  5. Question about flush-mate
    By zorro55555 in forum Toilet Forum discussions
    Last Post: 04-20-2005, 04:36 PM
