Move the tub or reframe...
I am remodeling a bathroom in an old house that was converted from a barn to a house in the 50's. The joists are 3x5 with 1 3/4 LVLs sister to them and they are 16" oc. The joists run parallel to the long side of the tub. This doesn't leave much room for plumbing and cutting the joists is not an option. I made a mistake when designing the bathroom layout (don't know what I was thinking) when I assumed that the tub drain pipe that goes through the floor was centered under the tub drain. Of course, the pipe should have been centered under the overflow. No matter which way I move the tub (left to right looking at the tub from the end), a joist is in the way. The tub is positioned in the corner of a room and there is a curbless walk-in shower next to the tub.
Does anyone make a tub drain that centers the drain pipe under the tub drain opening? Is there another creative option? I have looked at different tubs (center drain, side drain) and they all put the drain right over my joists!
Any help would be greatly appreciated.
Gene
The Watco unit is cable operated and I have never been a fan of that type of operation. To me, a better fit would be either an "expensive" brass tubing model with either a trip lever or "push/pull" stopper, or a plastic one, such as the "Global Industries" $22.00+/- one with the push/pull stopper.
Jaclo makes a nice brass Direct Outlet Toe Control Tub Drain http://www.chicagofaucetshoppe.com/J..._p/jac-397.htm
Once I knew what I was looking for, I found several of these types of drains. I also found a side outlet that opens up all kinds of possibilities for tub placement. http://www.jaclo.com/products/detail?pid=1295&cid=170
I can't thank HJ and Terry enough for steering me in the right direction.
