Results 1 to 6 of 6
Thread: Help!! Very lost and probably being ripped off!!
    DIY Junior Member Flagada's Avatar
    Mar 2013
    San Antonio, TX
    Default Help!! Very lost and probably being ripped off!!
    Hi, I'm new to this forum. My wife and I moved down to San Antonio TX from Canada. We just purchased a brand new home built at the end of 2012 that requires a water softener - which we know nothing about. It's a decent size home with 5 bedrooms/4 full bathrooms. Fridge has a water line, kitchen sink with high pressure hose & dishwasher. The lot size is 15,500 sqft with an automatic sprinkler system. Although it's just us and a dog, we will have family over regularly which could put 2, 3 or all bathrooms in use several times during the year.
    The builder recommended a water softener company. The sales guy recommended the Reionator Classic - $3250 tax & installation included. I haven't done a water test on the house yet (haven't closed on the house yet and I don't even know where you get those done). I've been told by locals that they happily use anything from a Sears bought $600 Kenmore system to a $4,000 Pellican or Culligan system...
    Where do I start without making this too complicated! Thanks!
    Jan 2012
    California
    Considering the large size of the house, you will need a larger softener. Wait until you close on the house and post more information for us to make a recommendation.
    The reionator has some Anion resin in it. This will have little affect on the water quality unless you are trying to remove tannins, sulfates, nitrates, etc. Does your water have this? If it is a municipal water system then probably not.
    Non salt systems work completely different than salt based systems, and most of the professional on this forum are probably going to recommend a salt system due to our many years of experience with both system designs.
    We would need to start:
    Pipe size of the main line where the softener is to be installed.
    Municipal or well water (your own well, not if the municipality uses a well)
    Water hardness (your city will have a water report available online or you can call them and ask them)
    If you have your own well, then you will probably be required to have a new test done, that will include all of the information we need.
    Good luck on the new house, and congrats on moving to San Antonio, it is a beautiful town. I visit there a couple times a year and always enjoy it!
    I can refer you to many great companies in that area that will give you an excellent price if you want.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I sold the Reionator in Austin for a few years. A lot of customers complained about a fishy smell with them and we had to replace some of them with a standard softener. The anion resin is suppose to remove chlorine in city water. As Dittohead stated, post the water test results or the city water report and we will provide good info so you can make an educated decision.
    Jan 2012
    California
    Quote Originally Posted by mialynette2003 View Post
    I forgot about that, the fishy smell of anion resin is never enjoyable. Without my books and cheat sheets on the topic, if I recall correctly the problem occurs when the anion gets depleted, the amines are the cause of the bad fish smell. This is a common issue with disposable DI cartridges. The other complaint we here with Anion resin is the water smells and tastes like a newspaper.
    Mar 2013
    San Antonio, TX
    Wow...definitely do not want fish or newspaper smells & taste in my water!! LOL...
    As far as recommendations, please PM some. I'd love to know that I'm working with someone reputable.
    Here's some more info:
    - Municipal Water System
    - 1.5" pipe (I was told that is not a standard)
    - See Hardness data below since I haven't tested my water yet..
    Here's the averages for my region from SAWS:
    Constituent Concentration Range
    Aluminum (ppm) < 0.00127 0.0109
    Calcium (ppm) 60.8 103
    Chloride (ppm) 11.9 25.4
    Copper (ppm) 0.00116 0.109
    Iron (ppm) < 0.0500 0.153
    Magnesium (ppm) 11.2 20.5
    Manganese (ppm) < 0.001 0.00928
    Silver (ppm) < 0.001 0.0152
    Zinc (ppm) < 0.004 0.131
    pH 7.4 7.9
    Sulfate (ppm) 10.4 53.6
    Total Alkalinity as Calcium Carbonate (mg/L) 124 262
    Total Dissolved Solids (mg/L) 242 356
    Total Hardness as Calcium Carbonate (mg/L) 198 316
    Hardness as Calcium/Mg (mg/L) 180 310
    Jan 2012
    California
    Your water looks to be easily treatable. The 1.5" pipe is very normal on larger houses and is based on flow velocity codes based on the plumbing material. Copper pipe (cold water) has a maximum recomended velocity of 8 Feet per Second. So a 1.5" copper pipe would be rated for approximately 44 GPM. The tube inside the walls can often be Pex which has a much higher velocity rating of 12 feet per second so the pipe size will drop significantly. The pipe size is based on the assumption that all of the faucets and fixtures could all be used at the same time.
    Hope this helps.
  1. Getting ripped off?
    By Humor in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2009, 01:42 PM
  2. lost pressure
    By nopressure in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-21-2009, 04:32 PM
  3. Ripped open the ceiling
    By sibi1972 in forum HVAC Heating & Cooling
    Last Post: 10-14-2008, 09:06 AM
  4. Did I get ripped off with new water heater?
    By mdhouseowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2006, 08:00 PM
  5. try again...lost prime
    By pump? in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-29-2006, 05:09 PM
