Results 1 to 12 of 12
Thread: Hansgrohe ThermoBalance II
    DIY Junior Member jointoday's Avatar
    Mar 2013
    california
    Default Hansgrohe ThermoBalance II
    I am finally getting around to installing a Hansgrohe Thermobalance II that I bought a few yrs ago. Do I rely on the pipes (and the clamps that hold the copper pipes) to hold the valve in place? There isn't any screw holes in the valve for attaching it to anything.
    JR
    DIY Member Killer95Stang's Avatar
    Mar 2012
    Southern CA
    Not a pro. plumber...
    Clamping the rigid piping (if using copper) or clamping around the valve body itself is the best way. Just make sure you use similar metals for the clamps... ie.. don't use galvanized plumbers strap on copper piping.
    Not sure how long you have been holding on to that Thermobalance, but if you haven't bought the trim, I suggest going with the Ibox instead. So many more choices in trim and a lot easier to install. Not to mention, the unit has ears for mounting screws.
    There are no ears on the TB2 rough. Using blocking and copper pipe clamps is recommended. This is one of the many improvements made with the I-Box compared to some older roughs. If you need any other help feel free to contact Hansgrohe Technical at 1-800-334-0455. Press 2 for tech and ask for David Scarborough. I'll be happy to help.
    Jul 2009
    North Vancouver, BC
    post(s) deleted by John Whipple
    We do not have any valves or controls for steam. Most steam units have their own proprietary valves and controls so it is just not cost effective to design and build them. Our I-Box is designed to be an integral part of the shower enclosure and does come with a membrane that goes around the box and seal it to the wall backing material. If installed properly this rough will be water tight to the enclosure and steam would not be an issue.
    Jul 2009
    North Vancouver, BC
    There is a gasket/membrane the comes with the I-Box. It is a black fiber material designed to work with practically any wall type or adhesive. It does help to seal the rough to the wall and keep moisture from migrating into the wall. It helps to make the I-Box an integral part of the shower enclosure.
    Jul 2009
    North Vancouver, BC
    Default Waterproofing Hansgrohe Fixtures with Kerdi
    Jul 2009
    North Vancouver, BC
    Default Hansgrohe ThermoBalance II - Kerdi Installation Overview
    Jul 2009
    North Vancouver, BC
    Default Making a Kerdi Flashing for a Hansgrohe ThermoBalance II installation
    Jul 2009
    North Vancouver, BC
    Default Hansgrohe ThermoBalance II - Kerdi Approval Markings A118.10 cUPC
    Jul 2009
    North Vancouver, BC
    Default Removing the trim ring on the Hansgrohe Rough In
  1. Grohe vs Hansgrohe
    By DougB in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2013, 11:24 AM
  2. Hansgrohe Help!
    By Barbham1 in forum Shower & bathtub Forum & Blog
    Last Post: 01-31-2012, 05:58 AM
  3. Thermobalance III with Kohler Handshower - vacuum breaker or check valve?
    By strawberryblond in forum Shower & bathtub Forum & Blog
    Last Post: 04-05-2010, 04:55 AM
  4. Hansgrohe thermobalance 11
    By lsil in forum Shower & bathtub Forum & Blog
    Last Post: 02-02-2009, 03:15 AM
  5. thermobalance(Hansgrohe) vs. thermostatic (Grohe)?
    By hjchicago in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2007, 08:20 AM
