Results 1 to 8 of 8
Thread: Should I seal or not
    DIY Junior Member Ottawa97tj's Avatar
    Aug 2013
    Ontario Canada
    Default Should I seal or not
    Should I seal the gap between the Kerdi board and tub flange? If I do should I use Silicone or Kerdi Fix?
    Jul 2009
    North Vancouver, BC
    Post(s) deleted by John Whipple
    Aug 2013
    Ontario Canada
    Darn, yeah it's already up, I have access to the back of two of the walls and will install blocking, the one wall is an outside wall (opposite the shower head) so am out of luck with that one, thanks for the tips.
    John is in conflict with Schluter and doesn't seem to understand that it is the foam that is the waterproofing on KerdiBoard. There are several ways to deal with the flange. Does the KerdiBoard go down over the flange? Did you use shims to prevent it from bowing out? You can fairly easily notch the back of it so it sits flush over the flange without the bow which will support it all along that edge...depends on how tall the tub flange is. Some are fairly tall, some are quite short (typical on CI, plastic ones are usually much taller).
    If you notch it, a bead of Kerdifix on the flange would be plenty to anchor the KerdiBoard to the flange and provide a waterproof seal. The alternative is to use some Kerdiband, and seal the edge to the tub with KerdiFix.
    You might want to view the videos on the Schluter site, or give their (very helpful) tech support people a call.
    Aug 2013
    Ontario Canada
    Darn looks like I have some rework to do, thank goodness I didn't start tiling. Unfortunately the Kerdi board is just butted up to the top of the flange biggest gap I would estimate at less then an 1/8. All my seams and fastners have been Kerdi banded. I put Kerdi Fix between the Kerdi board and the top of the tub flange (acrylic tub) so the flange is pretty high. I added blocking to the two wall I had access to.
    So my question is should I cut out a couple of inches of the Kerdi board at the bottom to notch the back so the Kerdi board overlaps the flange and add the blocking to the one wall I didn't have access to and then Kerdi Band the new seams or will the Kerdi Fix provide enough support and water protection?
    Aug 2013
    Ontario Canada
    Also could point me to the Schluter video that takes you through the steps for a tub surround, I tried looking through the site and only found a shower stall installation.
    Jul 2009
    North Vancouver, BC
    Use some Kerdiband and apply a band of it over the bottom of the kerdiboard onto the tub lip as if it were a joint between boards. Seal the bottom edge of the Kerdiband to the tub flange with Kerdifix. In fact, it may be easier to put a bead of Kerdifix on the edge of the Kerdiband and thinset on the Kerdiboard, and then just embed the band onto the assembly.
    The folks at tech support are quite well verses in their products and can help guide you through this.
  1. Replies: 8
    Last Post: 02-25-2013, 06:01 AM
  2. To Seal or Not to Seal the Stair Landing
    By chefwong in forum Remodel Forum & Blog
    Last Post: 02-05-2012, 05:35 AM
  3. Jumbo Wax Seal/Double Wax Seal?
    By SteveMar in forum Toilet Forum discussions
    Last Post: 08-23-2009, 08:44 AM
  4. To Seal or not to Seal, that is the question?
    By Mntnbkr in forum Shower & bathtub Forum & Blog
    Last Post: 01-26-2006, 05:31 AM
  5. Wax Seal
    By George in forum Toilet Forum discussions
    Last Post: 09-05-2005, 04:30 PM
