Thread: air in brine tank tube
    DIY Junior Member wully31's Avatar
    Mar 2013
    Iowa
    Default air in brine tank tube
    so I cleaned my brine tank and put water and salt in them manual regenerated our after several hours, well I don't think I put enough water in the brine tank and the tube was sucking water out with air pockets from the brine tank to the softner cause the water ran out. What do I do, will it just fix itself next time it regenerates?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    All softeners have a devise (air check) to prevent air from being drawn during the brining cycle. If you could hear air being sucked into the brine line, the air check is bad and needs to be replaced. The air check is either in the brine tank (very end of the tube going to the bottom of the brine tank) or it's a clear plastic cylinder mounted on the softener valve.
    Feb 2011
    NW Ontario, Canada
    I think most if not all softeners draw out all of the brine and still have time left over on the brine cycle. As mialynette said, there is a device that should stop air from being sucked continually during the remainder of the brine cycle. On mine, the device does not seal perfectly so I see some air bubbles go up the brine line.
    If too much air is allowed to enter the cylinder, you will have air above the resin and may hear the sound of water splashing (like peeing in a toilet) during use.
    Loose brine line compression fittings is the primary cause of air in the brine line. That assumes there is water over the end of the brine pickup tube. If there is air after the water gets down to the air check height, then the ball type check valve in the brine pickup tube or on the control valve is leaking.
  1. GE GXSF40H Brine tank overflowing
    By KStatefan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-12-2012, 05:54 PM
  2. 4" Plastic Tube in Brine Tank Cracked
    By TJanak in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-04-2011, 11:33 AM
  3. Brine tank almost overflowed
    By LLigetfa in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-03-2011, 01:41 PM
  4. Brine tank filling up with too much water
    By eldyfig in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-23-2011, 10:51 AM
  5. Brine Tank Question
    By Truckman in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-20-2009, 09:58 PM
