Results 1 to 7 of 7
Thread: Distance of 1/2" water pipes
    DIY Junior Member muskymike's Avatar
    Mar 2013
    Wisconsin
    Default Distance of 1/2" water pipes
    Hi all, new here. I'm in the process of adding a new shower and need to get water over to it. It is roughly 25 feet from any water pipes that I can access easily. They are only 1/2". Will this be ok for the shower to feed that distance?
    Will there only be one showerhead and no other load? Depending on what else runs from that 1/2" line, none may work well if all are running. 1/2" works well with one load (outlet)...it can be problematic when you start to add more outlets.
    Mar 2013
    Wisconsin
    Hi Jim, how ya been? Yes there will only be one shower head and the shower won't be used much. The lines I'm planning on tying off from are running to the kitchen.
    Long time no see! Been fine, retired, enjoying myself. All modern shower valves are required to have anti-scald technology, so if someone did open the kitchen faucet or turn on the dishwasher, you wouldn't get scalded! Since they are flow restricted, too, you may not notice at all.
    Jul 2009
    North Vancouver, BC
    I'm confused guys. You chat every day on the John Bridge tile forum. Why are you acting like you just met on the street.
    Musky Mike you have 15,230 post as of today and Jim has 7,429 posts on the John Bridge forum. Seriously you are going to act like you just met? Weird. JW
    Mar 2013
    Wisconsin
    John what does that have to do with my question? I met Jim in person about 5 years ago. I don't talk to him everyday.
    Thanks Jim, I know about the antiscald valves I have installed lots of them. I was just worried about running the 1/2" lines that far with out having a volume drop.
    What KIND of 1/2" lines are you running? Copper, CPVC, or PEX. If either of the last two, then it will be undersized for that distance. John, on another forum regarding computer problems, I once had one person asking the question, and her "suite mate" at the next desk answered it as if they did not know each other and had never met.
  1. How to Clean & Sterilize "Whirlpool" style Tub Pipes and Jets ?
    By Beski in forum Shower & bathtub Forum & Blog
    Last Post: 03-04-2013, 10:55 AM
  2. Polybutylene QEST "Quest" pipes in my home
    By TF52 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2012, 11:33 AM
  3. Toilet Vent Distance @ 6' - 9", bad idea?
    By djsoot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2012, 05:59 PM
  4. Replies: 4
    Last Post: 11-15-2007, 08:06 PM
  5. "Singing/Whiring" Water Pipes
    By ironwmnmk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2005, 04:27 PM
