Thread: Heat recovery unit and recirculation piping
    DIY Junior Member steelsparky's Avatar
    Mar 2013
    FL
    Default Heat recovery unit and recirculation piping
    While I may not be a plumber, I have been called a freon plumber. I do refrigeration and A/C and just got a deal on a heat recovery unit which uses the discharge line to heat water.
    While I can easily figure out the A/C side of it, I am curious about the water side piping involving the tank. I also plan to add an active recirculation loop from the furthest fixture. And add pump @ tank.
    Question is can someone tell me the correct way to pipe this configuration? Can't seem to find any diagrams on the internet and the HRU I got did not come with any directions. Have a 40gal tank with in, out, and drain port.
    Also can anyone recommend a good grundfos recirc pump? House is on a well.
    Tom
    Exactly which unit did you buy? Sounds like this is using the a/c line to preheat some water. Is there nothing on the manufactuer's website that contains this info?
    Mar 2013
    FL
    I'll have to get an exact model serial but it's a Trevor Martin. And yes it preheats the water. The hru says to tee off cold water supply at the tank and then pipe return into the drain. So I guess my next question is where do I pipe the return for the recirculation loop? Also in the drain?
    Mar 2013
    FL
    Ok here is a piping diagram for the HRU. http://www.hotspotenergy.com/heat-re...thout%20TT.pdf
    Where do I pipe the recirculation loop back to tank, tee into drain line also? Use check valves? Thank you
  1. Heat Recovery Unit for shower
    By C Williams in forum Shower & bathtub Forum & Blog
    Last Post: 01-18-2012, 03:56 PM
  2. Drainwater heat recovery installation
    By jch in forum Water Heater Forum, Tanks
    Last Post: 12-18-2010, 08:18 AM
  3. Takagi's new T-H2 - PVC Venting and Heat Recovery
    By Noth Jersey in forum Tankless Water Heater Forum
    Last Post: 10-16-2009, 06:33 AM
  4. Drain Heat Recovery Unit?
    By michaelene in forum Remodel Forum & Blog
    Last Post: 03-07-2009, 11:34 AM
  5. Combustion Air Intake Efficiency / Heat Recovery Ventilators
    By jjohanson in forum HVAC Heating & Cooling
    Last Post: 02-05-2009, 01:54 PM
