Thread: Sump pump wont start
    DIY Junior Member pumpnewbie's Avatar
    Mar 2013
    British Columbia
    Default Sump pump wont start
    Yesterday I used my Liberty sump pump model s35 (spec sheet: http://www.paulsupply.com/files/LibertyS35.pdf )
    and it was working great. I had plugged it manually and forgot. About 4 hours later, I remembered that the pump was still powered on. The water had been completely drained and I think that the pump had been still running for about 3 hours or so thereafter with no water left. I noticed that the motor had stopped. I tried to re-plug it to restart but it wont start. I waited some hours because it has thermal protection but it still wont start.
    This morning I put the pump in a large bucket and filled it full with water since the pump has a Automatic Diaphragm Switch built into the pump. Nothing. The motor didn't even hum.
    Is it possible that the motor burnt out? Is there anything that I should try to get it going again? The power outlet is fine. I dont know the 1st thing about mechanics but hope the pump can work again. help
    Jan 2008
    It's a submersible pump which should never be run without water flowing through it.
    Unless you are very lucky, it is ready for the scrap pile.
    Mar 2013
    British Columbia
    I thought the motor was dead but yesterday I plugged the sump pump into the outlet and I could hear the motor lightly humming (the pump was not in water I was trying it one last time before chucking it and then this low hum... ) so now I don't know whether it can work again or ... ?
  1. pump wont turn on
    By tressie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-22-2012, 07:20 AM
  2. pump wont come on
    By jrmcmil in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-18-2009, 06:54 PM
  3. Reputation of ABS Robusta sump pump / sump pump configuration issues
    By ct-esq in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2008, 06:41 AM
  4. lennox pulse g14Q3 wont start
    By possum in forum HVAC Heating & Cooling
    Last Post: 10-22-2008, 06:22 AM
  5. Well pump wont prime
    By mifirecop in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-25-2007, 10:45 AM
