Results 1 to 10 of 10
Thread: What kind of maintenance has to be done on a rainsoft softening system?
    DIY Junior Member mrginas's Avatar
    Feb 2013
    fl
    Default What kind of maintenance has to be done on a rainsoft softening system?
    I have a used rainsoft softening system .it has been disconnected for about two years. Before that it was working fine. Before I hook it up to my new home what would have to be done with it to make sure it's running properly. There are two tanks besides the brine tank . I assume one is a carbon filter tank and the other is a resin tank. Do I have to change any of the resin or carbon,in these tanks? What yearly maintenance is preformed on this equipment ? What is the life span of these systems? How often do you have to change the carbon,resin in this system? I have looked on line for a maintenance manual for this system but I have had no luck in finding one. I have spent many hours on line trying to find this stuff out. Thanks for taking the time to look at this post.
    Central Florida
    I found a half dozen or so manuals for various Rainsoft systems after a few minutes' Googling. If you could tell us the exact model number and supply pictures of the overall system and control heads, I'm sure the pros who hang out here could give ou the right scoop.
    Feb 2013
    fl
    Quote Originally Posted by Mikey View Post
    Hi Mickey
    Sorry it's been so long for a reply to your post.i will be taking pictures of the rainsoft system this week. I also live in cent Florida near Ocala . Do most plumbers in this area know how to seta system like rainsoft up?
    Thank you. Tom
    Central Florida
    I can't speak for all plumbers, but I would imagine most would have some knowledge of softeners. RainSoft may be proprietary enough that it can only be serviced fully by authorized RainSoft service facilities. There is a RainSoft dealer locator on the Web; choosing a random Ocala ZIP code for the search, I found Florida Energy Water & Air, Inc., in Archer, but have no experience with them. I do have experience with Los Aviņa Mexican Restaurant in Archer, though -- excellent.
    Feb 2013
    fl
Size:  45.6 KBName:  image.jpg
Size:  33.2 KBName:  image.jpg
Size:  43.6 KBName:  image.jpg
Size:  43.6 KBOk so this is what I have. I got this from my daughters house in Charleston sc . It was put in by the former owner. The water in that house was not hard but the owner was sold a bill of goods. My daughter had it un hooked about two years ago when she had a new hot water tank put in. I got it and now and was wondering if it is worth while to have it hooked up. One tank I think is a carbon pre filter but I'm not sure. They have been sitting for two years not hooked up .do I have to change the resin and carbon? Can a new valve be installed on the tank? The system was put in around 2001 in SC , maybe used for about ten years. I don't know if the rain soft tanks are universal, if they are I was thinking of using them and just replacing the timer and valve. This system was working when it was taken out. Hopefully the pictures will come thru.
    Feb 2013
    fl
    Sorry for the double pics ,it was a learning curve , lol
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Resin can be tested to see if it is still good. Get a sample and squeese it between thumb and finger. If it smaches up it no good. Carbon is a breeding ground for bacteria. Being unhooked for 2 years is not good. Seeing it is a health issue, I would replace it to be safe. I don't believe the tanks can be used for another valve unles they have an adpator converting a standard tank to fit the Rainsoft valve. Send a closer pic of were the valve mounts to the tank.
    Feb 2013
    fl
    Quote Originally Posted by mialynette2003 View Post
    Here are the pics.....Name:  image.jpg
Size:  45.7 KBName:  image.jpg
    Nov 2010
    Ocala, Florida
    It does not look like they used an adaptor to convert a standard tank. Rainsoft thread and tank opening size are not standard so you will not be able to use another valve on those tanks.
    Feb 2013
    fl
    That's what I thought ,and thanks for your response .
  1. what kind of system should i install constant or large tank
    By 85ray in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-22-2013, 11:30 PM
  2. Rainsoft AQB Series E
    By Max1956 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-26-2013, 08:35 AM
  3. Softener not softening?
    By 70runner in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-10-2012, 11:27 AM
  4. rainsoft system
    By kamr60 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2011, 06:38 PM
  5. How to remove Rainsoft
    By suem600 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-24-2009, 06:06 PM
