Results 1 to 15 of 15
Thread: Terrible solution in my basement for washer. Recommendations?
    DIY Junior Member Erick Smith's Avatar
    Mar 2013
    Default Terrible solution in my basement for washer. Recommendations?
    Hi all! Nice forum!.
    I have a basement washer and dryer. The basement only has a 2" wasteline (1965 build) so I had a plumber in to find a workable solution because the previous homeowners simply put the washer drain into the sump well. Obviously not code or good for the environment....
    So the plumber put in a lift station and approximately 7 ft of pvc for length and tied into the 2". Problem is that the lift station is too strong and causes the water to back up into my lower level sink and over flow.
    Here's a picture I took. I did a little bit of diagramming too to describe things.
    If you notice in the picture, the lift station goes up, then turns towards the camera, loops down then to the waste line.
    Any ideas what I can do?
    Here, the inspectors like to see a 4/10 hp pump dumping into a 4" line.
    3" could maybe work, but a 2" is going to have issues. Once you go from pumped to gravity, things start to slow down.
    Is there a way to intercept a larger line outside the foundation? Normnally you would find a 4" at some point. Or at least bring the pumped 2" to that 4" line.
    Mar 2013
    No, the main line it on the other side, opposite of the bathroom on the other side of this wall.
    Jan 2008
    The pump needs to connect to the building drain, which is 3" or 4". Depending on the plumbing layout and accessibly, sometimes it is easier to make the connection on the outside of the foundation.
    The right way is not likely to be the easy way.
    You could also have a partially clogged drain line if the backup is that severe. But, since it appears that they used a 2" ejector pump, rather than the more common, and appropriate, 1 1/4" sump pump, that could also be the problem since it has a very powerful discharge capacity.
    Mar 2013
    So it could be as simple as a 1 1/4" lift rather than this beast? As well as ensuring a clean line? I had used some of that drain chemical stuff that sits in there and slowly eats away but Im guessing it only works on big stuff.
    Like hj mentions, you're only pumping a washer. Using a smaller pump would help.
    Mar 2013
    Those smaller ones easy to find? Im afraid the previous plumber only had access to this monster locally.
    Mar 2013
    Im actually wondering if I even need the pump. The reason we did all this was because of the slight washup to the sink. Wondering if it's just clogged and a good cleanout would resolve all of this because a washer pump isnt nearly as strong as this pump.
    Jan 2008
    The plumbing code requires a washing machine to be drained into a laundry tray or a standpipe. It would violate the code to install a properly trapped and vented standpipe high enough to drain into that cast iron line.
    quote; I had used some of that drain chemical stuff that sits in there and slowly eats away but Im guessing it only works on big stuff.
    In my opinion, it doesn't work for ANY stuff. Believe me, a 1 1/4" pump is a LOT easier to find than that beast, but he made a much bigger profit by using it. The washer COULD pump up to a "P" trap properly installed into the drain line, BUT, it would overflow and flood the basement any time the drain got partially clogged.
    Mar 2013
    It had worked in my case because my upstairs kitchen drain was backing up to this same lower level sink im having issues with now and when i poured that crap down the kitchen drain, the lower level sink eventually gurgled a few times then it finally drained. But I guess I could have a trustworthy plumber look at this and I take the knowledge I've obtained here to have them give me proper service.
    Wish I found this place a few years ago. GIANT wealth of knowledge here. Thanks
    Feb 2005
    Cool throttle it down and see if that dont work
    that is a pretty expensive sewage pump that the plumber installed
    a simple solution to the problem might be just to clean out the drain
    then install a 2 inch ball valve in out going line above the check valve...
    then basically throttle down the ball valve to about 1/4 of the way open to
    slow down the flow///
    a ball valve is pretty cheap and easy to install and I I am wrong
    you have not spent a fortune on the experiement
    check out my new web site is the girl hot or not??
    http://plumberindianapolis.com/
    DIY Senior Member Rich B's Avatar
    Sep 2008
    New Jersey
    How high is to high for a washer standpipe?
    I have 2 in my basements and since the 4" waste line exits the foundation wall at about 3 feet the standpipe tops are about 5 feet off the floor. They are 2" and vented and work fine.....
    I have wanted to add slop sink and could easily dump the washer into the sink with a pump and pump the water up and out.....but then the next issue is connecting that pump to the waste line and removing the standpipes.....
    Jan 2008
    Quote Originally Posted by Rich B View Post
    Here the standpipe must extend from 18"-36" higher than the weir of the trap, and the top cannot be more than 48" above the floor.
    I like the Liberty sink pumps. The 404 is great for a slop sink. I would like to try the the 405 direct-connected to a standpipe in the future.
  1. Washer Drainage in Basement
    By vinny140 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-13-2012, 04:40 PM
  2. Basement Bathroom - Shower Recommendations?
    By tweedlet in forum Shower & bathtub Forum & Blog
    Last Post: 10-02-2011, 09:22 AM
  3. Washer in basement-drain
    By jmailer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-02-2009, 07:02 AM
  4. Washer in Basement
    By impeyr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2008, 03:18 PM
  5. driveway/basement flooding solution
    By mrphilip in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-26-2007, 10:18 AM
