This is bigger than a one week DIY project! First, you must start with a good design plan. All the big companies, Toro, Rainbird, Orbit, etc will provide something like that, usually free. They may even provide a parts list of all the heads, etc. Just assume you will need to buy several hundred feet of pipe....in most likely a mix of 1", 3/4", and 1/2". This is where the design comes in, because if you undersize the piping in any part of the system, it will never work right.
You need to decide what kind of pump you need....and comes the design again.....you have to have the system designed into zones so the flow rate on any zone will not exceed pump capacity.
Sprinklers are a good DIY item, but it is more complicated than you may think.
