Thread: 2 inch pipe to P Trap
    DIY Member dw85745's Avatar
    Oct 2004
    Arizona
    Default 2 inch pipe to P Trap
    I have a 2 inch horizontal drain line running through the wall cavity that I want to
    turn out for a bath sink. Just found out they don't make 2 inch trap adapters.
    My thoughts are to downsize to 1-1/2 pipe in the wall cavity,
    then use a 90 degree for the turn and then use a 1-1/2 trap adapter.
    Question:
    Is there a better way?
    Jan 2008
    It would be helpful to see what you are dealing with, particularly what else is connected to the drain and where the vents are or will be.
    Your idea is correct, but whether you can, or should, connect to that "drain line" is open for debate since we know NOTHING about it. Normally you would NOT be permitted to do it without additional design and piping work.
  1. Cleaning 4 inch trap, what to use?
    By dripdrip in forum Drain Cleaning
    Last Post: 05-16-2011, 04:28 PM
  2. 1 and 1/2 inch trap adapter for 2 inch drain?
    By maxfischersweet in forum Shower & bathtub Forum & Blog
    Last Post: 11-19-2009, 05:57 PM
  3. 2 inch p trap in 2x6 bay
    By Pblazer in forum Plumbing Forum Discussion & Blog
    Last Post: 11-17-2009, 06:07 AM
  4. 2-inch trap between 2x8s?
    By flanneljammies in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2007, 07:44 AM
  5. Cutting 2 inch and 3 inch copper pipe
    By JohnO in forum Plumbing Forum Discussion & Blog
    Last Post: 11-09-2006, 10:35 AM
