Results 1 to 2 of 2
Thread: hot water tank overflow
    Default hot water tank overflow
    I had my hot water tank replaced a year ago and for the last couple of months I keep hearing burping come from the tank. The overflow is causing the noise and I have to keep emptying the bucket because it will over flow itself. How can this be fixed ?????? THANK YOU
    Kevin
    Plumber jimbo's Avatar
    Most likely a pressure problem. 1) the pressure in your house might be high and 2) regardless of your house pressure, it is likely you need an expansion tank installed on the cold water inlet pipe.
