Results 1 to 11 of 11
Thread: Sharkbite Stop Valve for Toilet
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    Default Sharkbite Stop Valve for Toilet
    I'm thinking of replacing my old soldered-on toilet shut-off with a Sharkbite - available at HD.
    Once I've cut out the old valve with my tubing cutter:
    How much of a stub-out is needed for the Shark to slip over?
    How should I prep the stub-out (remove any residual solder, etc.)? Emery cloth?
    Do these things leak over time?
    TIA
    Aug 2009
    South*East
    Why not use a compression stop? In my opinion they're far better than shark-bites.
    John
    The pipe must be totally clean, round, deburred so there are no rough edges, and long enough. The deburring tool can also be used as the depth gauge for you to ensure it is inserted all the way. On 1/2" copper, I measure very close to 1" using their deburring tool, give or take a very small amount.
    Yakima WA
    I second the compression stop.
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Just curious, why do you prefer the compression stop over the sharkbite?
    Aug 2009
    South*East
    Compression fittings have been around for some time and have proven their reliability shark bites haven't
    John
    You need a much longer stub of copper out of the wall for a Sharkbite.
    Properly installed, a Sharkbite can rotate (it might be stiff, but it will). A compression stop won't. A compression fitting will seal (assuming you can get the ring on) if the pipe isn't quite round, a sharkbite may not.
    Retired Machine Repairman wptski's Avatar
    Oct 2012
    Warren, MI
    Being a DIY, I don't use compression fittings very often but the last time I did, I had a terrible time trying to tighten them enough to not leak.
    Bill
    Just a DIY'r
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    Put a couple drops of oil on the threads the compression nut tightens onto.
    Jul 2009
    Royal Oak, Michigan
    I haven't started this yet, but the reason I wanted to go Sharkbite over compression is due to lack of room. There doesn't appear to be enough space to manipulate two wrenches (wrench and counter-wrench).
  1. faucet / toilet supply risers and stop valve preferences?
    By Stu27 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2011, 05:03 PM
  2. Constant Pressure Valve/ Cycle Stop Valve Questions
    By gforce in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-25-2009, 11:45 AM
  3. Leaking stop valve on sink and toilet
    By puechini in forum Toilet Forum discussions
    Last Post: 01-09-2007, 06:56 PM
  4. Leaking stop valve on 1st floor toilet
    By terripellatt in forum Toilet Forum discussions
    Last Post: 09-13-2006, 01:29 PM
  5. Toilet Stop Valve
    By mrtigre in forum Toilet Forum discussions
    Last Post: 05-11-2006, 01:31 PM
