Results 1 to 5 of 5
Thread: White, wax paper like residue in Moen cartridge
    DIY Junior Member revie54's Avatar
    Mar 2013
    California
    Default White, wax paper like residue in Moen cartridge
    I have a strange thing happening. My tub faucet started leaking so I went to replace the cartridge as I have done a few times before. When I removed the Moen cartridge it had a bunch of pieces of little wax like paper stuck in different parts of the cartridge. I put in a new cartridge and it started leaking again a couple of days later. When I pulled out the new cartridge it also had this wax paper stuff clogging it up. Any ideas what this stuff is and how to get rid of it? Thanks.
    Small white plastic particles would perhaps be a water heater dip tube.
    Is it on the hot or the cold side?
    Mar 2013
    California
    Thanks for the reply. It is a single handle faucet. It does not look like the little residue that I see when I drain the hot water heater (it is real old) if that's what you are talking about.
    Mar 2013
    California
    It is more like little tiny strips of wax paper
    There was a batch of water heater dip tubes that failed - they literally broke up into small white flakes. An old WH might have had one in it...that event was a long time ago. This did two things: clogged up valves, shower heads, and aerators; and, caused you to run out of hot water faster since instead of adding the cold water to the bottom of the tank, it mixed with the hot at the top.
  1. Moen tub cartridge?
    By chopped in forum Shower & bathtub Forum & Blog
    Last Post: 12-29-2012, 08:09 AM
  2. white residue from faucet install?
    By hogu in forum Plumbing Forum Discussion & Blog
    Last Post: 10-24-2012, 07:00 AM
  3. Brown Constuction Paper --- Builders Paper
    By chefwong in forum Remodel Forum & Blog
    Last Post: 02-01-2012, 05:16 PM
  4. new moen cartridge won't go in
    By skylyn in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2011, 11:40 AM
  5. New Water softener, but still have white residue in water
    By DiHydrogenMonoxide in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-29-2009, 07:34 PM
