Results 1 to 2 of 2
Thread: Where should I buy my water softener from (and capacity question)?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default Where should I buy my water softener from (and capacity question)?
    Look to buy a Fleck 5600sxt 48,000 grain capacity softener.
    I've been told ohiopurewater.com and qualitywatertreatment.com are both good sites, among others. Well...which would you choose?
    Also, i've heard that the sizing calculators are wrong (on these sites)...is there any better way to size it?
    Jan 2012
    California
    Online sizing calculators are pretty good sometimes. Gary has a calculator on his site that is better than most. The most common factors that need to be considered are hardness in GPG, compensated hardness for Iron and excessive TDS, how many people in the house, fixture counts, pipe size, etc.
    Most companies tend to go with slightly larger equipment the necessary to ensure the system is adequate for the application and future growth. The "48000" grain system is more realistically a 32000 grain system. Systems should be sized to regenerate no more than every 6th day for single tank systems. Anything beyond 8-10 days nets very little gain in efficiency but it does not hurt a system to regenerate infrequently. Every 30 days should be the max (no real reason why, just common practice), and most systems are programmed with an automatic overide to force a regeneration if the system does not exceed its capacity by that time. Old style electromechanical systems will sit indefinitely between regenerations if the meter does not zero out.
    If you have iron, more frequent regenerations are preferred to lessen the fouling of the resin bed.
    Hope this helps.
  1. How is softener capacity programmed or calculated with lower salt usage?
    By teve in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-31-2011, 08:09 AM
  2. Well Capacity Question
    By molo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-23-2008, 08:02 PM
  3. Water heater capacity upgrade
    By export in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-28-2008, 12:50 PM
  4. Well-X-Trol tank capacity question
    By paullyboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-18-2008, 09:29 AM
  5. Water softener question
    By Alexdc99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2006, 09:59 AM
