Results 1 to 7 of 7
Thread: Clack WS1 / Error 2002
    DIY Junior Member Ted A's Avatar
    Mar 2013
    North Las Vegas
    Default Clack WS1 / Error 2002
    Hi, I'm in need of help. I bought a complete water softener (Clack WS1) system a few years ago for a home I had just purchased that was in need of lots of repair. During the repair work I had a heart attack an everything was reduced to a slow crawl.
    This past weekend I was finally able to install my brand new system only to get an error code 2002 / unexpected stall (after regen).
    I've disassembled it several times & can't seem to see any mechanical problems.
    The motor seems very strained at times (it slows way down).
    Before I disassembled it the first time whole face of the controller was moving & it felt like something was going to snap inside.
    The troubleshooting guide in the manual shows 9 different causes for this problem.
    I was hoping someone could help me narrow down the probable cause of the error.
    Again this is a brand new never used unit purchased May 2010.
    Ted
    Jan 2012
    California
    Remove the cover and put the system into regeneration. pay careful attention when removing the cover, the buttons are a bit fragile on the board and Clack will not warrant broken buttons.
    The system "homes" by stalling the motor when the piston reaches its limits. This is a unique design and it is normal to hear the motor get "bogged" down at the end of the piston limits. If the motor stalls or binds in the middle of the stroke, that could indicate a problem with the seal pack/piston. Do not lubricate these items, they are water lubricated. Here is a short tutorial on the valve tear down.
    Mar 2013
    North Las Vegas
    Dittohead, Thanks for the reply. I've previously dissembled every thing in your video at least 4 times.
    The owners manual shows 9 items under error 2002 unexpected stall.
    (pretty wide range of stuff from board, motor etc. etc.)
    I did originally purchase from Gary & was hoping he would reply also.
    It should still be under warranty but not sure how that would work with their anti homeowner policy.
    Ted
    Hi Ted, sorry to hear of the problems you've had and I hope you're doing well.
    I don't recall having a 2002 error code before and don't know why you can't see a cause for it but... call Clack and tell them you bought it from me and per Bob Bishop, I told you to call.
    Explain the problem as you have here. I suspect it could be a motor problem if you can't find another cause. Or, how about the three gears, do they rotate without binding? Have you removed the stack and with a flashlight made sure there is nothing in the back of its hole that is preventing the stack from being inserted far enough? Or maybe don't do anything until you're on the phone with someone at Clack. Which means you should be ready and able to take your phone to the valve, or valve to the phone, and let them hear the motor run etc.. Clack should take care of you.
    Mar 2013
    North Las Vegas
    Thanks Gary, I really appreciate your reply.
    Ted
    Nov 2010
    Maine
    I'm pretty sure that calling Bob isn't going to get you too far. I'd almost bet that if he does speak with you he's just going to tell you to contact a Clack dealer/distributer in your area. Calling Clack directly is one of the things that caused them to pull internet sales in the first place.
    Ted, I gave you the specific instructions Bob Bishop gave us internet dealers to give to our customers in the event we went out of business. Plus I've had a few other customers do it and have not heard that any of them had a problem.
  1. I need help identifying this country kitchen faucet, circa 2002..
    By TheGreenPlumber in forum Plumbing Forum Discussion & Blog
    Last Post: 07-01-2012, 12:09 PM
  2. PWR OFF Error on RAINBIRD ESP-TM8
    By robertp17 in forum Irrigation / Sprinkler Forum
    Last Post: 07-30-2010, 10:39 PM
  3. Old error biting my behind
    By Gary Swart in forum Plumbing Forum Discussion & Blog
    Last Post: 05-22-2009, 09:38 AM
  4. York Furnace and A/C 2002 - wire cut.
    By Tim429 in forum HVAC Heating & Cooling
    Last Post: 07-15-2008, 10:29 AM
  5. thinset error
    By paul730 in forum Remodel Forum & Blog
    Last Post: 01-03-2006, 04:57 PM
