Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Propane Grill Regulator Problem??
  1. #16
    quote: What I have to do is: turn the bottle off, unhook the hose from the low pressure side of the regulator to "bleed it", reconnect the hose, open the bottle slowly,
    The tank has a "valve" in it that detects sudden flow and closes the outlet since it assumes something has broken. It stays closed until you stop the flow and allow it to "drop back" into its open position.
  2. #17
    Oct 2011
    Thats it in a nutshell
  3. #18
    Mar 2011
    Houston, TX
    Quote Originally Posted by Hammerlane View Post
    Turned out to be the regulator. Picked one up from local gas grill house along with an oetiker clamp and a barbed connector. Burner works fine now.
    Only thing is the new regulator only has a single output so I can't use the side burner and the cylinder needs to be rotated 90 degrees an d now I need a bungee to secure it.
    Was the vent hole on the old regulator open ?
    Did you try the bang method to UN-stick the regulator ?
    Side burners are handy, but not really necessary.
    Nice that you have it working.
  4. #19
    Oct 2011
    Old reg did have a vent hole and I did try the bang method a few times.
  1. main water presure regulator problem
    By jack99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2013, 07:40 AM
  2. propane auto changeover two stage regulator on a house...
    By jrc0210 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-11-2011, 04:15 PM
  3. The Jet Bar & Grill
    Last Post: 01-25-2008, 01:18 PM
  4. Propane Pipe Sizing & Regulator placement
    By FredC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2007, 11:08 AM
  5. Converting propane grill to natural gas
    By rkpatt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-19-2006, 10:34 PM
