Results 1 to 9 of 9
Thread: Can I hydro ban a schluter presloped shower pan? And other stuff.
    DIY Junior Member Jenms's Avatar
    Mar 2013
    Default Can I hydro ban a schluter presloped shower pan? And other stuff.
    Hi. I'm working on a bathroom redo. (This is long, sorry.) I have it down to the studs and subfloor. I have a few technical questions. I'm doing it myself (capable female here) with the help of my brother and lots of reading. Even though I'm doing it myself, I want to make sure it is done correctly and won't leak. I have looked everywhere trying to find if I can use hydro ban on the schluter tray. I can't find anything in any of the forums. I know from all of my reading, most say "stick with one company product and go with it". I'm trying to find an alternate method for my shower floor so I don't have to build a mud bed. I have already bought some hydro ban. Here is what I would like to do, but will it work?:
    My shower is on a corner of my house sitting over a basement crawl space. My subfloor is only 1/2 or 5/8 inch plywood. I was planning on putting another 1/2 inch on top of that. (Isn't minimum 3/4 inch?) Either cbu or wood.
    I would like to use the schluter tray (thinset to wood floor), apply thinset on top to fill holes and level it, then apply 2 or 3 coats of hb on top of thinset, then tile. Will that work with those 2 different company's products? I know there wont be the 25 year warranty, but thats ok if it will work. I just don't want a leak. Thoughts? IF that works, then:
    Drain. Will the flanged hb drain (my preference) work/fit on the schluter pan, or do I actually need the kerdi drain? I couldn't find that information anywhere either.
    If I build the mud pan and put hb on top of that, will a foam curb work, or should I build that too with 2x4's?
    With the mud pan, do I need to add anything to it besides the sand and cement? I've read about laticrete's 3701.
    I am not planning on tiling the walls. I want to install cultured granite panels on top of the cbu walls. So I will have tile on floor, granite panels, accent tile above panel, then additional panel next to ceiling. I also want to put in a niche with the accent tile. Sequence? Do I tile the floor first, then set the panels on top of the floor? Or set the panel on top of the shower pan, then tile to the wall?
    I'm going to build a bench as well. Do I have this right? Frame, 3/4" wood top, 1/2 inch cbu, hydro ban, whatever top I choose to put on it? Then the same on the front- My question here is sequence again. Do I cut cbu to length of subfloor, then put tray against the cbu, tape it, then hydro ban it, or only cut cbu to top of pan then tape and hydro ban?
    I know laticrete has the shower pan as well with the drain built in, but it's $400. I'm trying to shave costs where I can. I actually called schluter to ask them, and the response was "I don't know".
    Sorry for all the little stuff. I appreciate any help anyone would like to offer.
    Jen
    Jul 2009
    North Vancouver, BC
    post(s) deleted by John Whipple
    JW
    He's asking about using the Schluter tray, no Kerdi at all, and just HydroBan on it.
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    Default Silent Cheer for Laticrete!!!
    DIY Junior Member ShowerProj's Avatar
    Mar 2013
    Dallas, TX
    Question Response - Need Help!
    Way to go John!! I am new to this Forum; and live in Dallas, TX. I am embarking on existing 46"x 31"x 68" shower conversion to steam room of 46"x 31" x 120" upto the ceiling, with 2 frame-less glass sides joining 2 tiled floors. I propose changing out the plastic shower pan with mud-built floor. All ceiling, floor, and walls will be tiled over hardi backer, with a cinder-block reinforced seat too.
    I welcome recommendations on how to ensure vapor-proofing and water-proofing, while eliminating leaks and mold, etc in future.
    Also I am considering a 9KW steamer from SteamSpa, Coast, SteamIt/Mr Steam, or Kohler.. Any recommendation or pros and cons of either manufacturers??? I am leaning towards the SteamSpa at $1800 for 9KW steam generator, including 2 digiital control pads, a multi-colored strobe light, steam head, and wrings. Other features include self cleaning, Built-in auto-drain, Proprietary dual-tank technology, Continuous Steam. QuickStart™ technology for hot steam output in under one minute; Steamhead
    Led ambient light; Dual control panels; Filter to soften water before it goes into the steam generator. WOULD YOU RECOMMEND THIS STEAM GENERATOR?? Thanks
    SHOWERPROJ..
    Quote Originally Posted by johnfrwhipple View Post
    Jen is getting a new Hydro Ban Shower system for her home. The folks at Laticrete have stepped up and decided to help out this family.
    I heard back from Henry and he tells me it's as simple as that. Jen's husband is deployed overseas and her friend is helping her.
    Reading between the lines I'm guessing they frowned upon the Hydro Ban over Kerdi system.
    I'm blown away at the generousity of Laticrete (Well done guys!) and am going to take a special interest in this project as well.
    Jen is humbled by this experience as I guess you can imagine. It's not everyday a complete stranger sends you products for your home. Jen did not know Henry was the owner of Laticrete when she emailed him - she just reached out looking for help.
    She got it. Big time!
    Yeah!!!!
    JW
    Jul 2009
    North Vancouver, BC
    Mar 2013
    Dallas, TX
    Thanks John..
    Jul 2009
    North Vancouver, BC
  1. Replies: 2
    Last Post: 02-09-2013, 01:52 PM
  2. Schluter's Line Drain - A closer look at the new linear shower drain from Schluter
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 07-15-2011, 07:47 AM
  3. Orange Mold in a Schluter Systems Kerdi Shower - Linear Trench Drain
    Last Post: 06-14-2011, 08:54 AM
  4. Schluter-Kerdi shower install needed
    By cclearly in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2008, 01:06 PM
