Thread: low voltage remote control dimmer
    Writing, constructionDIY Member Yersmay's Avatar
    Sep 2005
    Los Angeles
    Default low voltage remote control dimmer
    I am hoping that someone knows of a dimming system that will work for me... I built a bookcase and am in the process of planning a low voltage lighting system. There will be 3 separately controlled items -- There will be four LED strips that will be dimmed together. Next, there are two low voltage cans that need to be dimmed together. And finally, a single low voltage can that needs to be dimmed all by itself.
    I already have the transformer but now I am looking for a multi-channel low voltage remote control system that will accomplish what I've described. I have searched around and I seem to be having some trouble finding this. The multi channel dimmers all seem to be configured so they control a multi-colored LED strip. But that is different than what I need.
    The guts of the system will be placed above the cabinet, behind the crown moulding -- I mention this because there may not be a direct line of sight for a remote signal. It is my understanding that a radio frequency remote will work in this case.
    Thank you in advance.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    I hope you know that LED strips do not need a transformer, but rather a driver.
    They need smooth DC, the details of which are beyond my ability to describe. Obviously they are readily available.
    What you are looking for sounds VERY custom and I will be surprised if you find what you need in a catalog.
    Mar 2011
    Houston, TX
    You may want to use a dimmer like this one ;
    http://www.jameco.com/webapp/wcs/sto...001_2153140_-1
    It is good for 8 amps Max. at 12-24 Volts DC. Rectify the AC output of your transformer. Jameco sells rectifiers.
    Then you could use a X10 or similar RF remote for control.
    Jameco also sells parts to make Robots , So that books can be selected and brought to your arm chair.
    All you would need then is a Membership to Weight Watchers.
    Enjoy.
  1. WIFI thermostat - inexpensive solution for remote control
    By JerryR in forum HVAC Heating & Cooling
    Last Post: 10-29-2012, 06:06 PM
  2. trouble shooting low voltage control operates high volt can lights
    By cwhyu2 in forum Electrical Forum discussion & Blog
    Last Post: 07-14-2011, 12:49 PM
  3. Flickering lights on circuit with low voltage and line voltage bulbs
    By davidwie in forum Electrical Forum discussion & Blog
    Last Post: 04-18-2011, 07:34 AM
  4. Running low voltage in high voltage boxes
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-22-2009, 07:27 PM
  5. Remote control load switch?
    By snafflekid in forum Electrical Forum discussion & Blog
    Last Post: 08-04-2007, 02:26 PM
