Results 1 to 8 of 8
Thread: Retrofit meter with remote read
    DIY Junior Member Fraser Jim's Avatar
    Nov 2009
    Fraser, CO
    Default Retrofit meter with remote read
    Have a well with an indoor water meter. County is requiring the ability to read on outside of home. Meter body marked Precision 5/8"PMM, with meter marked Invensys PMM. It has a rotating clock type pointer and then a analog display showing gallons used.
    Can anyone suggest a retrofit that could go on the meter with a display that I could mount outside??? Only about 1' to outside wall, so hard wired is preferable.
    You would have to check with the meter manufacturer to see if they have a remote reading module that would attach between your meter and its dial. Otherwise you need a new meter.
    I know that water rights are different in the arid west, but is it common for the municipality to actually care how much water you pull out of your well? Or, is it a shared well provided by them?
    Nov 2009
    Fraser, CO
    Water law and water rights are a big deal in Colorado. We have our own well. The development has purchased water rights to a fixed amount of water.. Even though we are on our own well, we have to prove that we are not taking water that isn't ours.
    AZ is the same way, at least for large wells.
    DIY Member Stuff's Avatar
    Mar 2013
    Pennsylvania
    You could ask the county what they support so you don't do it twice. Last year my meter was swapped out with one that can be read wirelessly. Old one did have the remote on the outside of the house that was removed. Apparently they no longer want to have a meter person leave their vehicle to read the meter.
    DIY Senior Member Hairyhosebib's Avatar
    Jun 2010
    Arizona
    Quote Originally Posted by Fraser Jim View Post
    This seems really absurd. If it is water coming out of your own well what do they care how much water you use! This seems like another BIG BROTHER INTRUSION! I am certainly no fan of wireless meters. Most Smart Meters emit more radio waves than OSHA says is acceptable. There are tons of people trying to get rid of them and now people are being arrested for standing in the way of them being installed on their own homes. Smart meters are being proved of causing all kinds of health issues. I would sure like to get rid of mine. But then again I have all kinds of other electronic things that are proven to be bad for me too. Like my wireless computer equipment.
    In much of the west, you buy the land, you do not buy the mineral and water rights underneath it. There are obviously exceptions, but it all depends on what's in your deed. The water underneath is a shared resource just like you can't divert all of the water from a surface stream, apparently, you can't suck excessive amounts of water out of the ground. WHen I lived in El Paso, the city bought some land in NM and then wanted to put in a well. Since it was in NM, and on the 'other' side of the mountain, the aquifer was different...NM shut that down quickly. Water is life, and there's not an unlimited supply which is why we have the flow restrictions on things like showerheads, faucets, and toilets.
  1. Read at your own risk
    By Cookie in forum Health and Wellness Forum
    Last Post: 09-12-2011, 09:07 PM
  2. Can remote electric meter reading cause circuit breakers to trip?
    By njghost in forum Electrical Forum discussion & Blog
    Last Post: 04-12-2011, 04:38 PM
  3. Please read rules
    By Terry in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-21-2009, 02:35 PM
  4. Testing 220V with multimeter. What should the meter read?
    By TXTom in forum Electrical Forum discussion & Blog
    Last Post: 11-01-2007, 03:09 PM
