Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Getting correct Delta T readings
  1. #16
    DIY Junior Member Fred-nk's Avatar
    Mar 2013
    Western PA
    I think you are reading the Taco 007 pump curve chart correctly http://www.taco-hvac.com/uploads/Fil...ry/100-1.8.pdf.
    Interesting chart here http://www.csemag.com/single-article...97efe75bd.html
    What is your actual return temperature?
  2. #17
    DIY Member tom3holer's Avatar
    Mar 2013
    Cape Cod
    Return temps vary with output temps but as mentioned earlier they are in the range of 5-8* lower.
    This seems to be true on both the primary and secondary loop
    Tom
  1. Delta 1700 Thermostatic valve - don't see this on Delta site
    By SliderJeff in forum Shower & bathtub Forum & Blog
    Last Post: 07-27-2009, 07:10 PM
  2. Why are these voltage readings normal?
    By scubar in forum Electrical Forum discussion & Blog
    Last Post: 06-22-2009, 04:12 AM
  3. Odd readings replacing an outlet.
    By 73Electra225 in forum Electrical Forum discussion & Blog
    Last Post: 10-11-2007, 03:08 AM
  4. Voltage readings
    By jimbo in forum Electrical Forum discussion & Blog
    Last Post: 09-04-2007, 08:03 AM
  5. Gas furnace readings
    By pedietz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-22-2006, 06:59 PM
