Thread: Laundry Sink into Washer Drain Stand Pipe
    DIY Junior Member koellert's Avatar
    Mar 2013
    Wisconsin
    Default Laundry Sink into Washer Drain Stand Pipe
    This has been occupying a lot of my time... and I thank you all for your help so far!
    I am thinking of going back to my original plan to put a laundry sink closer to my washing machine. Not knowing much about plumbing, originally I was simply going to "T" into my washing machine stand pipe. Thankfully, someone warned me about siphoning, sewer gas, etc.. Though the attached "plan" might not be ideal, would it work? Am I right in thinking that I wouldn't have to care if this setup siphoned my sink's p-trap since there is a trap below that will block sewer gas? To me, it doesn't seem any different than the current setup of having the washing machine drain hanging into the top of the open stand pipe. What am I missing in my way of thinking?
    Thanks again for all of the advice offered!
    Two traps never works well...no that would not work satisfactorily. And, you might end up with water in the sink when the WM drains.
    Jan 2008
    Each fixture must have it's own trap. Each trap must have a vent.
    In WI it is required that the washer trap be above the floor.
    Our code is not too much different than in other states.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Just do away with the trap under the sink since you are going into the stand pipe anyway and it will work and you can live with it no matter how it looks or smells
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. Washer stand pipe requirements
    By bpetey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2012, 12:34 PM
  2. Adding a Laundry Sink to Existing Washer Drain
    By bradleonard in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-22-2010, 03:53 PM
  3. Washer stand pipe, trap, and drain within one stud bay
    By bsperr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-29-2010, 08:01 AM
  4. Alteration to Washer Stand Pipe
    By jeffro626 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2009, 02:32 PM
  5. add laundry sink to washer drain?
    By djbabyk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2008, 08:19 AM
