Results 1 to 4 of 4
Thread: Adjust Temp on HJ-40 cartridge?
    DIY Junior Member JLang17's Avatar
    Mar 2013
    MN
    Default Adjust Temp on HJ-40 cartridge?
    My shower never gets hot enough and I would like to allow for more hot water to come through. I disassembled the handle and the cartridge is an HJ-40, seen here: http://www.vimadecor.com/retail_prod...cid=46&subid=0
    I cannot figure out how to adjust the hot water limit on this thing...if it's even possible. Does anyone know how?
    Thanks.
    There should be a "limiting" ring that fits over the cartridge to control how far the stem can rotate towards the hot side. The cartridge itself is NOT adjustable.
    Mar 2013
    MN
    Thank you. I now have it adjusted, but I lost one of the gasket rings in the wall and now it leaks. It is the seal on the very back side of the cartridge and is shaped like a bubble "T". Do you know if I can buy just this ring or do I need to replace the whole cartridge? If I can buy the ring, where?
    Plumber jimbo's Avatar
    I have never seen those rings sold separately. There are literally dozens in not hundreds of different configurations. Who would want to stock those???
  1. Can someone help identify the cartridge brand/model? Moen Posi-Temp
    By tr1006 in forum Shower & bathtub Forum & Blog
    Last Post: 11-13-2012, 04:25 PM
  2. AquaSource Shower - How Does 'Flow Control' Cartridge Gear Inside Handle Adjust?
    By Technic-Fan in forum Shower & bathtub Forum & Blog
    Last Post: 04-22-2012, 04:38 PM
  3. New Moen Posi-Temp Cartridge - Still NO Cold Water
    By tlkpts in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-17-2012, 03:58 PM
  4. Moen Posi-Temp 1222B Shower Cartridge
    By SteveMar in forum Shower & bathtub Forum & Blog
    Last Post: 08-11-2011, 02:09 PM
  5. Shower is freezing, how to I adjust the temp valve?
    By jayson in forum Shower & bathtub Forum & Blog
    Last Post: 11-16-2009, 07:06 PM
