Results 1 to 2 of 2
Thread: Water temp
    DIY Junior Member karter56's Avatar
    Feb 2013
    Charlotte, NC
    Default Water temp
    I recently replaced the water heater that runs to the water coil on my hydronic furnace. Can anyone tell me what temperature these systems typically run at? The old system had no gauge on it at all. I'm currently running it at around 140 degrees.
    140 is a common number...anything over 120 (and in some places it doesn't matter, you) need a tempering valve to limit it to 120-degrees. Having higher storage temperature gives you a greater quantity of hot water since you'll almost always be mixing it with cold, either via the tempering valve or at the point of use. This means you don't need as much hot volume for things like a shower (makes no difference on the quantity of hot used to say fill a tub, though). Mine is set to 140. A higher temp also means things can't grow in the warm water, which is a good thing. A typical indirect WH has great insulation, so there is not a lot of standby loss verses say a gas fired WH.
  1. Boiler water temp
    By t56tr in forum Boiler Forum
    Last Post: 09-16-2010, 07:29 AM
  2. LOW Temp or HIGH Temp AQUASTAT for WH?
    By Handiman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2010, 09:52 AM
  3. supply temp ver: return temp
    By rrekih in forum HVAC Heating & Cooling
    Last Post: 04-12-2010, 03:56 PM
  4. Replies: 8
    Last Post: 02-02-2010, 04:19 AM
  5. Water Heater Temp
    By Mikeyboy in forum Water Heater Forum, Tanks
    Last Post: 01-25-2009, 09:27 PM
