Thread: Second toilet line hits main one in opposite direction of flow to the ejector pumop?
    DIY Junior Member ghurty's Avatar
    Mar 2013
    NY
    Default Second toilet line hits main one in opposite direction of flow to the ejector pumop?
    I have a basementName:  plumbing.jpg
Size:  11.6 KB where I am putting in two toilets. I need to have an ejector pump as well.
    Due to the position of the toilets and support beams, The line where the second toilet meets the first line is heading in the opposite direction of the flow from the toilet. Will this cause issue?
    See attached image.
    Use an elbow and a wye pointed in the right direction to connect the middle toilet to the line...you need the wye pointed towards the pit or you'll end up with problems by slowing it down and having to change direction, then potentially jamming stuff up it from the left toilet.
    Yes
    Water always goes down hill and downstream.
    You can forget picking up your check this week.
    The connection for a second toilet NEVER "has" to connect backwards, and CANNOT do it. You just need a better piping design or a plumber who knows how to do it properly.
  1. water flow indicator on main line
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2009, 07:12 PM
  2. Gasketed pipe direction of flow
    By johnwayneit in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-09-2009, 06:24 AM
  3. Sewage ejector and low flow toilet
    By Dianeh in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-31-2009, 09:04 PM
  4. Direction of water flow stickers for pipe?
    By Billy_Bob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-11-2008, 07:37 AM
  5. direction of sewer line in basement??
    By tameria11 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2008, 07:51 AM
