Results 1 to 2 of 2
Thread: PEX or PVC - which is more sensitive to caulks, flashings and sealants
    DIY Junior Member oak orchard's Avatar
    Jan 2013
    Western New York
    Default PEX or PVC - which is more sensitive to caulks, flashings and sealants
    I presumed that O2 barrier PEX and PEX in general is more likely to be compromised by various VOC's and solvents in poly urethane, butyl, asphalt flashings, and and spray foams than PVC. But I am told by a plumber that PEX is much heartier than PVC.
    PEX can be used for water inside a home, and also CPVC
    PVC can only be used for underwater supply of cold water.
    Waste and vents can be ABS or PVC, depending on local code.
  1. Single Lever Shower Valve Ultra sensitive and difficult to adjust temperature
    By Tenderpaw in forum Shower & bathtub Forum & Blog
    Last Post: 05-17-2010, 09:30 AM
  2. How sensitive are cpvc fittings to twisting
    By pinetree in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-09-2009, 05:13 PM
  3. Thread Sealants question!
    By ItryDIY in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-30-2009, 08:22 PM
  4. thread sealants
    By scott99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-03-2007, 08:25 AM
