Results 1 to 6 of 6
Thread: is liquid in tank cleaner like Ty D Bol bad for toilets?
    Default is liquid in tank cleaner like Ty D Bol bad for toilets?
    I know this is probably a really dumb question but I have been asked it a lot. is liquid in tank cleaner like Ty D Bol bad for toilets?
    Anything you install in the tank that dispenses its contents into the tank is likely not good for the rubber components. Not sure exactly what's in that, but anything that contains bleach will render the rubber components (the flapper valve, and maybe other things) into slimy crud in short order. One company makes a system that mounts in the tank, but goes in series with the bowl refill hose, and dumps it down the overflow rather than the tank. That shouldn't mess with the tank's rubber components, but will sit in the bowl until the next flush.
    Yakima WA
    Every manufacturer advises against cleaners that are dispensed in tanks for the exact reason Jim explained.
    Apr 2012
    New York, NY
    Everything they say above is true. I just looked at the TyDBowl MSDS and it looks as if it contains mostly detergent and dispersants; no mention of chlorine, which is the real bugaboo for rubber. That said, the other junk isn't likely to actually help the components even if it doesn't harm them as clearly as chlorine does.
    Thanks, I won't be making that mistake again anytime soon.
    In the Trades joemcl's Avatar
    Mar 2013
    Pennsylvania
    If you read the paperwork that comes with the toilet it states use if in tank cleaners voids mfgr. warranty.
  1. Are Toilet Bowl Cleaner Tabs Safe to use with Toto Toilets?
    By DanMcD in forum Toilet Forum discussions
    Last Post: 12-22-2012, 05:45 PM
  2. Preferred liquid membranes
    By jimbo in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2012, 06:38 AM
  3. Replies: 1
    Last Post: 03-07-2012, 01:27 PM
  4. OFU Music at the Liquid Lime in Kirkland
    Last Post: 06-30-2007, 09:00 PM
  5. PC-Cleaner registry cleaner to fix your errors
    By systemcleaner in forum Computers and Stuff
    Last Post: 03-03-2007, 07:03 AM
