Results 1 to 6 of 6
Thread: Cadet 3 Flowise 1.28 gallon "Help"
    Default Cadet 3 Flowise 1.28 gallon "Help"
    I have just recently replace my cracked Glacier bay toilet 1.6 gpf, with the Cadet 3 Flowise. After about two weeks after installation the toilet began to burp and shoot water and waste up into the air. I am on a septic system so i called to have my septic ventilation checked and tank pumped. After that was done the toilet burped again, this time the toilet filled up to the rim with water and then flushed down the outlet at a super quick speed. This was followed by a gurgle and no water in the bowl. So i called american standard they said they have never herd of a case like this and that they could replace the bowl or just take it back to the store. I am going to take it back but i was wondering should i trade it in or get the Kholer Cimarron 1.28 gpf HE toilet?
    or if you have any other options i will take into consideration, ps. The Toto Eco Drake i would have to order online because there is no local retailer/
    Apr 2012
    New York, NY
    I would call around to plumbing supply in the yellow pages and see if you can't find someone who carries the eco drake. CST744E is the model number. You can see what Terry's price is and use that as a guide to a fair price. If you can't find it locally, I would get it anyway, even with the method you are discussing, over the other alternative toilets you mention.
    It sounds more like there's an obstruction either in the toilet or in the drain line. There can't be anything in the line slowing discharge of the toilet, or it can fill to the brim. Anything , either inside the toilet or in the drain line that prevents the waste leaving as fast as it wants will cause it to back up. Since it backs up so far, that obstruction can't be very far away.
    If you used a wax ring with a plastic horn, depending on how it was installed, sometimes that itself can create an obstruction (if it is off-center or is compressed by the type of flange used).
    Question Second Toilet
    I also have another toilet on the same line, that is runs in tandems with the same line and it flushes just fine. Is it possible that the toilet has a clog inside its built in trap?
    That can always happen with any bowl. If the trapway is clear, it should work fine.
    Plumbers are always finding combs, toys, pencils, pens, crayons, etc. trapped in the trapway of toilets...any one or similar item can produce the results you are seeing. A toilet auger might pull it out, but may not. Sometimes, you have to pull the toilet and try from the bottom to get it out. Some trapway designs are worse than others for trapping things. Those with nice smooth, gradual curves are less likely as well as those with larger diameters, but any toilet can be clogged.
  1. Review: Cadet 3 EL Flowise Toilet
    By chrisf8657 in forum Toilet Forum discussions
    Last Post: 10-17-2011, 03:29 AM
  2. Price "guess" Tankless Water Heater/10 Gallon storage and existing recirc pump
    By anitarenner in forum Tankless Water Heater Forum
    Last Post: 10-28-2010, 02:34 PM
  3. Any experience with Cadet FloWise 1.1 GPF Pressure Assist?
    By FargoFan in forum Toilet Forum discussions
    Last Post: 10-01-2010, 10:52 AM
  4. Making a Flowise? - Bricking the Cadet 3 from 1.6 gpf down to 1.28
    By RickS in forum Toilet Forum discussions
    Last Post: 01-28-2010, 06:35 AM
  5. Toto Eco Drake or AS Cadet 3 Flowise for 10" rough-in
    By stickers11 in forum Toilet Forum discussions
    Last Post: 10-18-2009, 09:49 AM
