Results 1 to 3 of 3
Thread: Problem adding shower to clawfoot
    DIY Junior Member andejosh's Avatar
    Mar 2013
    WI
    Default Problem adding shower to clawfoot
    Purchased a faucet and shower kit for a vintage clawfoot. Installed the faucet w/out issue, but when I added the shower riser, the angle on it is way too steep. It rises away from the center of the tub at 30+ degrees. I need this to run vertical to tie into the surround.
    What am I doing wrong?
    Sep 2009
    Seattle. WA
    Might be that you're not doing anything wrong. I've had the same experience, caused by improperly made parts. This was an $800. faucet/shower set, and
    the supplier would not give satisfaction. There are clawfoot shower sets available where the shower riser has a swivel fitting at the bottom, so this problem
    can not arise. You might want to ditch/return what you have and get one of those.
    There is no standard on the angle of the tub wall, and if the kit relies on that and there's no adjustment, the shower riser won't be vertical.
  1. clawfoot shower combo
    By cam+dee in forum Shower & bathtub Forum & Blog
    Last Post: 02-18-2011, 12:50 PM
  2. shower enclosure for clawfoot bathtub
    By little d in forum Shower & bathtub Forum & Blog
    Last Post: 05-12-2010, 01:51 PM
  3. Help retrofitting handheld shower onto clawfoot tub spout
    By jch in forum Shower & bathtub Forum & Blog
    Last Post: 08-16-2007, 08:14 PM
  4. has anyone built a shower stall around a clawfoot tub?
    By srp4 in forum Shower & bathtub Forum & Blog
    Last Post: 07-12-2007, 01:26 PM
  5. Advice on choosing faucets (clawfoot tub, shower and sinks to match)?
    By carajon in forum Shower & bathtub Forum & Blog
    Last Post: 03-24-2006, 12:26 PM
