Results 1 to 7 of 7
Thread: Water softener resin is green
    DIY Junior Member earlrabbit's Avatar
    Jan 2013
    Salt Lake City
    Default Water softener resin is green
    I've been having problems with my 14 year old Northstar softener. I suspected that the resin might be bad as I've never run anything like "Iron Out" through it. After opening it up I see that most of the resin has an amber color but some has turned green. I don't see anything that looks like iron contamination. Is the resin bad? I've been inside the valve many times so I'm very familiar with it but is it time to bite the bullet and buy a new one?
    Nov 2010
    Maine
    Take a few beads and crush them between your thumb and forefinger. If they crush they are bad. Try it with both the amber and green beads. I suspect that either the resin is failing, the resin is channeled or the bed is not being properly back washed
    Jan 2012
    California
    Can you post a picture? Green might be an indicator of copper fouling. Considering the age and make, it might be a good time to start looking for a replacement system.
    Jan 2013
    Salt Lake City
    I was able to crush them between my fingers so it sounds like the resin is toast - right?
    Amber is a color of a resin. Green is usually from copper, so on site copper and pH tests would be in order.
    What is your raw test showing for pH, iron, total hardness etc.? Are you on your own well or 'city' water?
    Nov 2010
    Maine
    Quote Originally Posted by earlrabbit View Post
    Yep it's toast and considering the age of the equipment I highly recommend scrapping it and starting new.
    Jan 2013
    Salt Lake City
    Not sure on pH, but hardness is 13.85 grains/gal and iron is .03 mill/ltr. It's city water but they source part of their needs from wells.
  1. What does softener resin look like?
    By SteveW in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2011, 05:22 PM
  2. Softener resin
    By johnfin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2011, 04:05 PM
  3. Used water softener has a LOT of iron in the resin
    By snuffbox in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2008, 06:35 PM
  4. Can I replace the control unit on this water softener resin tank?
    By nazrat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-18-2008, 09:25 AM
  5. Water softener media and resin
    By Alexdc99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-11-2006, 09:13 PM
