Results 1 to 4 of 4
Thread: Ecowater softner
    DIY Junior Member woodsmith6's Avatar
    Mar 2013
    centereach new york
    Default Ecowater softner
    Hey Guys!
    I've had or rather got ripped off around 18 years ago when I purchased a Ecowater softener. Disassembled unit recently because i knew that my resin was shot (water flow at faucets was greatly reduced. water flow returned when unit was in bypass.) Examined media and found it to be like fine silt. Purchased new resin ( not Eco water resin! ecowater company must be government protected. Impossible to purchase parts ). Refilled resin tank 3/4 full, reassembled unit. Flushed system, ran water for a week now. NO SOFT WATER! What gives? Installed new spider gaskets lubed with silicone grease. It's almost as though water isn't passing through resin?! I set it to regenerate, brine seems to be functioning properly.
    Dec 2009
    Alaska
    After you refilled the media tank with the new resin and put the upper basket back into place, there should have been an O ring on top of the distributor , is it possible that the o ring is missing? broke?
    That is where I would be looking.
    Mar 2013
    centereach new york
    thank you! I will check that!
    Mar 2013
    centereach new york
    Thank you the "O" ring worked!
  1. water softener continuously runs to drain ECR 3500 Ecowater
    By 000utback in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-09-2013, 05:45 AM
  2. Ecowater 3000 series No water enters brine tank
    By RickC in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-20-2012, 02:41 PM
  3. EcoWater System Parts - Help
    By JayT in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-23-2011, 02:16 PM
  4. I have a new softner but???
    By MOVIE GUY in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-28-2010, 12:08 PM
  5. Ecowater System Refiner
    By nate620 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2008, 01:23 PM
