Results 1 to 3 of 3
Thread: New Tankless Water Heater
    DIY Junior Member tonyc37's Avatar
    Mar 2013
    Lenexa, KS
    Default New Tankless Water Heater
    I need a new water heater and I am thinking about a tankless unit.What I want to know is can I vent it through the existing vent from my old water heater or do I have to run a new vent.
    Aug 2009
    South*East
    Tank-less heaters need a 4" vent. Most tank type heaters are 3". Plus you may need a larger gas line. Tank-less are 3/4" and tank type are 1/2".
    John
    A tankless water heater is much more efficient which means more moisture in the exhaust. You "can not" use the old chimney.
    You will need either a new plastic or a new stainless. Most are being done with plastic.
    The old galvanized steel won't cut it.
  1. Tankless Water Heater for Tub
    By BlackNoir in forum Shower & bathtub Forum & Blog
    Last Post: 03-23-2009, 08:12 PM
  2. tankless water heater
    By r_harper in forum Tankless Water Heater Forum
    Last Post: 01-01-2009, 10:51 AM
  3. tankless water heater
    By renajames in forum Tankless Water Heater Forum
    Last Post: 06-05-2008, 09:25 AM
  4. Tankless water heater
    By Greg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2007, 04:25 AM
  5. tankless water heater
    By meckroth in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2006, 04:42 PM
