Results 1 to 2 of 2
Thread: Running 2 Taco zone pumps off one Taco controler
Hybrid View
    DIY Member tom3holer's Avatar
    Mar 2013
    Cape Cod
    Default Running 2 Taco zone pumps off one Taco controler
    Hi,
    I just had a new heating system installed in my home. It is a boiler/baseboard system with 5 zones.
    I have now discovered the installer really didn't have a clue as to what I really needed. He did no heat loss study and just assumed the old boilers rating was what I needed. I have ended up with a system that is probably 2x the BTU's that I need which causes it to short cycle much of the time.
    One of the things I have read that I can do to help this expensive screwup is to have more heat load. If I combine two of the three zones on the first floor that should help. Does anyone know if you can run two Taco 007-FS-71FC punps from one zone on a Taco SR-504 zone controler?
    Thanks,
    Tom
    In the Trades dwindle's Avatar
    Nov 2012
    North East Pennsylvania
    You can pull up to 1/3 hp per zone on that controller.
    I'd reccomend simply getting a larger pump.
    Your pumps are 1/25 hp.
    Make sure the temperature ranges on the aquastat are set far apart - this will reduce cycling and often add to efficiency.
  1. two zone circulator electrical connections taco to becket afg
    By d trois in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2010, 12:40 PM
  2. Replies: 0
    Last Post: 11-09-2010, 11:27 AM
  3. Taco Zone Valve
    By emaciat0r in forum HVAC Heating & Cooling
    Last Post: 12-30-2008, 10:47 AM
  4. Taco ESP Zone valves
    By Yaniguy in forum HVAC Heating & Cooling
    Last Post: 10-21-2008, 11:22 AM
  5. Wiring Taco SR 504 to start two pumps
    By patsfan in forum HVAC Heating & Cooling
    Last Post: 11-04-2007, 06:29 PM
