Results 1 to 3 of 3
Thread: UF-B or THHN in conduit for hot tub feed
    DIY Junior Member GlassCutter's Avatar
    Mar 2013
    Default UF-B or THHN in conduit for hot tub feed
    I am a serious DIY and am adding a circuit for a hot tub.
    The GFCI breaker panel for the tub will be 125' from the main breaker panel and will all runs will be out doors. My plan was to run 6 AWG between breaker panel and GFCI panel for the tub in 1" PVC conduit secured to the outer wall of the house. My question is do I need to run 6/3 UF-B or can I run 4 individual wires of 6 AWG THHN stranded?
    Scott
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    You MUST run THHN/THWN conductors since the outdoor portion of wiring to a hot tub MUST have a green insulated ground. The bare ground in UF cable does NOT meet this code.
    I must STRONGLY suggest you read up on Art. 680 of the NEC. An outdoor hot tub is treated almost exactly as a pool and the codes are specific and many. This is not a place to mess around if you don't know what you are doing.
    Mar 2013
    Thank you, I was sure that was the case but wanted another input.
    Have a copy art 680 and am reading through it.
    Thanks again.
  1. Feed from Breaker Panel
    By MrBillyd in forum Electrical Forum discussion & Blog
    Last Post: 02-20-2012, 10:14 PM
  2. gravity feed spring
    By Ridgeview Farm in forum Solar and Geothermal Water Heating Forum
    Last Post: 10-03-2011, 02:58 PM
  3. Dryer feed, how far is too far?
    By acrscout in forum Electrical Forum discussion & Blog
    Last Post: 03-16-2011, 12:40 PM
  4. Which line to use for water feed?
    By DIYourselfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2010, 06:57 AM
  5. Want to run new feed to garage
    By arfeller in forum Electrical Forum discussion & Blog
    Last Post: 11-26-2009, 09:44 PM
