Results 1 to 8 of 8
Thread: New electrical work question
    In the Trades dwindle's Avatar
    Nov 2012
    North East Pennsylvania
    Default New electrical work question
    Im sure there is a device for this.
    Say for example, you wanted to add an oultet in a wall. Is there not a sensor you could drop in the wall, which you would find with a detecting device from the basement so you could drill the hole through the floor?
    If not, what is the old school method for doing this?
    What if you were doing the same on a second floor?
    Aug 2009
    South*East
    Old school would be to use a ruler.
    John
    Old school would usually look for for an electrical wire going into that wall from the basement and measure to where you want to be. Or drill a small hole at the base of the wall and stick a wire through it. Or tie a string to a small powerful magnet and then use a compass in the basement to locate it. Greenlee also makes long, flexible drill bits, with extensions, that you push through the opening to drill the hole.
    Jan 2008
    When going from 2nd floor down, it's easiest to cut a hole in the wallboard above the baseboard and fix it when you are done. From an unfinished basement or crawlspace, i look at existing penetrations and/or nails coming down from above to determine where the walls are and measure from there. When uncertainty exists, I sometimes will drill an 1/8" hole down from the floor above, angling the bit so it comes through at the center of the bottom of the bottom plate. Once this is done, the hole is used as a reference in drilling up from below.
    Nov 2012
    I really like the magnet concept.
    Still, I'm surprised there isn't a simple device I could but to do the same thing. Will a compas read between a subfloor and floorplate?
    Measuring has screwed me in the past, because my only reference point is the interior walls, versus the basement walls, which may differ substantially.
    I don't want to cut a hole and fix it because there are too many custom paint colors and people demand invisible instalations. I've had people complain about access holes I've drilled in closets to repair shower controllers.
    Thanks.
    quote; I've had people complain about access holes I've drilled in closets to repair shower controllers.
    There is only ONE shower controller repair that needs an access hole and I am sure you have not run across it. Otherwise the only think that needs a hole is a shower valve replacement. A compass needle is finely balanced so it should have some response, regardless of how little when it is on edge and passes under a magnet. A commercial "dip needle" use a compass needle on the end of a handle to locate buried metal objects. There are devices, sending units and receivers, which while not exactly "simple", are effective and expensive.
    DIY Senior Member CanOfWorms's Avatar
    Feb 2013
    New Jersey
    I think all your questions will be answered here: http://www.terrylove.com/forums/show...iring-in-India
    Mar 2011
    Houston, TX
    That will work.
    You can also use a magnet and detect it with a Cheap Stud finder, or metal detector.
  1. Electrical Question
    By misterjw in forum Electrical Forum discussion & Blog
    Last Post: 01-24-2013, 01:13 PM
  2. Shady electrical work?
    By 1320ms in forum Electrical Forum discussion & Blog
    Last Post: 04-20-2010, 05:14 AM
  3. Shoddy Electrical work
    By davesnothome in forum Electrical Forum discussion & Blog
    Last Post: 11-07-2009, 07:24 AM
  4. Electrical Engineer allowed to do Electrical work?
    By willijimon in forum Electrical Forum discussion & Blog
    Last Post: 03-05-2009, 05:08 PM
  5. Electrical Work, Dryer Outlet
    By toolbeltbabe in forum Remodel Forum & Blog
    Last Post: 07-20-2006, 08:26 PM
