Results 1 to 1 of 1
Thread: Replacing olf furnace and water heater ( OIL )
Hybrid View
    DIY Junior Member quarry's Avatar
    Jan 2012
    Upstate NY
    Default Replacing old furnace and water heater ( OIL )
    I'm replaceing and 40+yr old Williamson forced hot air furnace 140kBTU/ 3.5 ton and Ford 30 gal water heater. both vent into a 20' Amerivent 7'' factory built double wall SS chimney ( see pic ). I have ask two small time Plumbing & Heating contractors in my area if its possible install a Toyotomi OM-148 ( Listed as a forced flue system ) on demand tankless water heater and a Carrier Performance 80 variable speed oil furnace and reuse the existing 7"chimney.
    Toyotomi OM-148 has a 2.5" flue and comes with an optional 5" adapter for use with chimney's. The Carrier furnace has a 6" flue. a local sheet metal guy said he could make a Galv 7" wye pipe with a 5" 45 degree to put the Toyo 5" pipe above the 6" furnace pipe and replace the existing 6" to 7" T as seen in the picture.
    I have not heard back from either guy. my suspision is they cant determine if venting will be an isuue or they are uncomfortable with the Toyo OM-148 WH. Has anyone ever done an install like this or have any venting experience with the Toyo. Direct venting the unit is not an option where it will be positioned.Name:  furnace.jpg
    Thanks, For any and all Help.
  1. Does running Furnace cause Tankless Water Heater to not heat water ???
    By cody21 in forum Tankless Water Heater Forum
    Last Post: 12-10-2012, 08:43 AM
  2. replacing old oil fired water heater and oil fired furnace.
    By quarry in forum Water Heater Forum, Tanks
    Last Post: 01-03-2012, 05:49 PM
  3. Replacing indirect water heater with gas fired heater?
    By MHM in forum Water Heater Forum, Tanks
    Last Post: 08-29-2011, 12:15 PM
  4. Gas water heater/Furnace combo
    By Southpaw134 in forum Water Heater Forum, Tanks
    Last Post: 08-27-2010, 12:52 PM
  5. Water heater pilot goes out when furnace starts
    By BillMorehead in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2005, 04:22 PM
