Thread: Kohler K-11748 Kohler Push button diverter Ever used/installed this? Vry few Reviews
    DIY Junior Member patma's Avatar
    Jan 2013
    Kentucky
    Default Kohler K-11748 Kohler Push button diverter Ever used/installed this? Vry few Reviews
    Hello, I am considering using the Kohler K-11748 for a bath remod however I can find very few reviews of this valve. Would like a shower head and rain head available but would like to avoid two separate valve bodys and trim kits. This valve seems to make sense.
    Any comments would be greatly appreciated.
    http://www.us.kohler.com/us/Rite-Tem...brandId=431762
    IF you connect two "shower units" to that valve, I am sure the one connected to the bottom , (spout), opening will act as an unintentional diverter and cause the other one to operate at thesame time. In other words, you would have the option of using either both, or the one connected to the top opening, but NOT one or the other.. However, they do show a piping arrangement with the bottom connected to a shower head, so the diverter may be "double seated" and shuts off the opening which is not in use. This would NOT be a typical diverter
    Jan 2013
    Kentucky
    Interesting. Thanks
    Saw this in the rough in notes: Installation Notes
    Avoid cross-flow conditions. Do not install shut-off device on
    either valve outlet.
    Guess this would mean both and not either on the diversion.
    Well, the upper unit would work with a shutoff device because the water has been shut off to the spout, but a shur off on the lower unit, or even "head pressure" from feeding the overhead shower would probably do the same thing as a partial diverter and send at least some of the water out of the other device. Something similar to a Pfister 016-DT1 or 15-388 which are the "double seated" center valve for a 3 valve fixture WOULD turn on either one or the other, and both if you did not turn it all the way in either direction.
  1. Moen push button diverter plug
    By badreligion9265 in forum Shower & bathtub Forum & Blog
    Last Post: 12-06-2009, 10:35 PM
  2. Push Button Diverter
    By stormyv77 in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2009, 08:06 AM
  3. Push Button Diverter stuck on Kohler K-305
    By jbanks100 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-03-2007, 06:39 AM
  4. delta push button diverter streams water
    By ironmandan in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2005, 08:09 PM
  5. Push-button diverter
    By DavidG in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2005, 03:12 AM
