Results 1 to 2 of 2
Thread: Need to remove solder from copper toilet drain
    DIY Junior Member Absberg2k's Avatar
    Mar 2013
    United States
    Default Need to remove solder from copper toilet drain
    I am remodeling a basement bathroom and in the process need to replace the closet flange for the toilet.
    This toilet has a 3 inch copper drain below grade. There is some left over solder inside the copper drain that I need to remove before I can attach the new closet flange. I'm just not sure how to go about doing that.
    I had considered using a torch to heat it up assuming it would then fall away and I would be left with a clean copper drain pipe. I am concerned though about using a torch near possible sewer gas. I cannot smell any sewer gas but understand it can be quite explosive.
    Is there a safe way to heat up and/or otherwise remove the leftover solder from the copper drain pipe? Is it safe to use my Benzomatic Propane torch? Anything I should do first?
    Thanks in advance for any advice.
    qupte; understand it can be quite explosive.
    I have never been able to get it to burn, forget about "explosion".
  1. HELP... DIY solder copper with water in them
    By Clarktul in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2009, 03:13 PM
  2. Solder Copper to Brass?
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2009, 05:38 PM
  3. Remove Excess Solder after I sweat pipe?
    By imunwell2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2007, 05:17 PM
  4. where to solder copper pipe
    By richb2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-14-2006, 07:29 AM
  5. can you solder copper and brass
    By Don Juan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2005, 06:54 PM
