It is NOT an insurance situation so forget about that as an option. If you use that shower base, then relocating the "P" trap and riser should be a simple process. The hardest part will be breaking the concrete, but you would have to do that even if you used a bathtub. It if was a "builder" error, then the plumber probably did what he was told to do, because we usually install whatever the blueprint for the building shows.
